ST185 swap- Having some Wiring Problems
Postby celicadreams » Thu Jan 27, 2005 8:29 am
I dropped a 90-91 st185 into my celica and I am using a Carlos Edition wiring harness, I was able to rewire the this harness to make it work with the ecu that came with the 90/91 engine, I was able fire it up and everything. I left the project in the garage for 2 months waiting for the axles and tranny parts, today I tried starting it again but it won't start, it cranks but won't start. When I turn on the ignition key, I noticed the ENGINE LIGHT doesnt come on. And when I turn the key to off, the engine light appears. I don't know what is wrong, I haven't touched it at all but it seems the problem is that it is not reading the ECU. If you are an expert with wiring, please help me out..
Return to FAQ / Archive
