Transmission Question
Postby celi_wabbit » Sun Feb 27, 2011 10:36 pm
Does anyone know if the 2nd gen trans bell housing would fit on the 4th gen 3sgte?
1993 MR2 N/A - Sold
1995 Tacoma - Sold
1991 Celica Alltrac - Sold
1994 Celica GT - Project
2010 Mercedes-Benz
celi_wabbit
Re: Transmission Question
Postby CMS-GT4 » Sun Feb 27, 2011 11:11 pm
It should since the Caldina manual gearbox was the same as the one from the st205.
Postby lumbercis » Mon Feb 28, 2011 2:47 am
^I'm not sure if this is what you meant, but the Caldina gearbox is an E150f, not the E154f from the ST205. But in any case they are all interchangable as far as bolting up to the engine.
Caldina powered...
lumbercis
Postby celi_wabbit » Mon Feb 28, 2011 4:24 am
Cool... just wondering if the RC trans would bolt up to a Caldina motor, and do you guys know if the clutch would be the same? Could you buy a 2nd gen clutch kit and flywheel and will work with the Caldina?
1993 MR2 N/A - Sold
1995 Tacoma - Sold
2010 Mercedes-Benz
celi_wabbit
Postby CMS-GT4 » Mon Feb 28, 2011 7:31 pm
lumbercis wrote:^I'm not sure if this is what you meant, but the Caldina gearbox is an E150f, not the E154f from the ST205. But in any case they are all interchangable as far as bolting up to the engine.
Is that true? I read the 4th gen 3sgte had the 205 box in the gt-t model. I need to go do research now as I was thinking of a Caldina gearbox since they are much cheaper. I may just change my FD in the rc box. Not sue yet.
Postby Gary ST165 » Tue Mar 01, 2011 7:24 pm
Manual transmission ST215 Caldina GT-T is an E150F (says that in EPC),
>> iirc it is not the same as the ST185 E150F (more info on Toymods forum )
echo: (Google search still works)
http://www.alltrac.net/phpBB2/viewtopic ... 83#p367483
Gary ST165 wrote:ST215 Caldina GT-T manual also features a E150F according to the VIN plate & EPC, but i have also been informed that it is different to the much earlier ST185 version, and hence more similar to the E154F found in the ST205.
http://www.toyodiy.com/parts/p_J_2000_T ... _3305.html
I haven'tlooked into gear ratios or final drive yet... but search Toymods or AUS & NZ forums as these cars are more common over there and lots of good infos.
ST165 turbo 4WD
Gary ST165
Postby celi_wabbit » Tue Mar 01, 2011 9:18 pm
This doesn't really answer me as the other was asking if he could use the trany from an ST215. Sorry if I wasn't being clear, I was wondering if I buy a Caldina engine, would my RC gen2 trans bolt into it and work? I'm not worried about gear ratio for I am still using the same trans.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
2010 Mercedes-Benz
celi_wabbit
Postby Gary ST165 » Tue Mar 01, 2011 11:41 pm
Flor of course, yes it will bolt up just fine ! 8)
ST165 turbo 4WD
Gary ST165
Postby celi_wabbit » Wed Mar 02, 2011 3:11 am
Hey thanks Gary, could always count on you when there is a question to be asked. :D :D :D :D :D :D :D :D
1993 MR2 N/A - Sold
1995 Tacoma - Sold
2010 Mercedes-Benz
celi_wabbit
Return to FAQ / Archive
