Switch to full style
Post a reply
interchange?
Mon Sep 12, 2011 1:52 am
Hey guys Im buying an alltrac and i need to know what internal parts are the same between st165 and 185
pistons
rings
rods
piston pins
bearings
crank
oil pump
water pump
timing kit
gaskets
valves
valve guides
valve springs
The alltrac im buying is a st165 and ewpi has a kit that is from 88-93 just wondering if i will get the right pats
Re: interchange?
Tue Sep 13, 2011 8:35 pm
:withstupid:
Re: interchange?
Sun Sep 18, 2011 8:28 pm
Again I found all the info I needed.
Re: interchange?
Fri Nov 16, 2012 4:40 pm
Some one please can this spammer
Post a reply
