ct20?
ct20?
Postby Rpz123isme » Sat Sep 17, 2011 1:35 am
I need the ct20 specs. if anyone has them it will help i'm trying to see what turbo is actually on this car
Hesperia, CA
Rpz123isme
Re: ct20?
Postby mk3_turbo_88 » Sat Sep 17, 2011 2:42 am
Are you taking about the ct20 or ct20b? The ct20 is out of the 22ret toyota truck. On the compressure housing there should be ct20 written on it. The ct20 to my knowledge has a different flange and will not bolt up to any of the ct26 manifold with modification. You should google ct20 there should be lot of spec for this turbo.
mk3_turbo_88
Re: ct20?
Postby Rpz123isme » Sun Sep 18, 2011 8:27 pm
ok i found all the info i needed.
Hesperia, CA
Rpz123isme
Return to FAQ / Archive
