For those who care to use a 3sge
• Page 1 of 1
a 3sge from a 88 gts is the same as a 88 3sgte. minus the oil squirters. but those are oil overkill because the rods have holes in them that serve the same purpose as squirters. i have read tons of threads where people say the 3sge has higher comp and different valves and such. Its all the same. valves,springs,pistons,rods,crank, most of the outer block. the more i have compared these two motors the more i believe that you could turbo a stock 3sge and have zero problems.
here is a pic i took at work of specs straight out of the book
Hesperia, CA
Hesperia, CA
Rpz123isme - Established Member
Re: For those who care to use a 3sge
Very nice information and very useful.
- alltraccamry
if you check out my project you can follow all the steps i took using a 3sge in my alltrac.
most of the steps where simple but none of my porting was necessary.
viewtopic.php?f=44&t=42125
Hesperia, CA
Hesperia, CA
• Page 1 of 1
