toyodiy reliable?
toyodiy reliable?
Postby aus jd 2703 » Fri Dec 23, 2011 6:19 am
hey guys just trying to figure out if my st205 front cut is zenki or kouki, early or late model for those less accustomed to jdm.
reason i need to know is ive heard there are two different rebuild kits for brake calipers depending on if the car is late model or early model.
so how reputable is toyodiy? it says its 09/1994
if some one has other means the chassis number is:
st205-0006303.
last but not least i didnt get the rear brakes so i am going to buy them seperately is there a way to tell with just the caliper if they are late or early model? cheers guys.
aus jd 2703
Re: toyodiy reliable?
Postby aus jd 2703 » Sat Dec 24, 2011 5:34 am
any body?
can ya tell the difference in the brakes?
aus jd 2703
Postby loudstealthGT-Four » Mon Dec 26, 2011 7:48 pm
give your local toyota dealership a call they'd be able to give you a definite answer
loudstealthGT-Four
Return to FAQ / Archive
