5x114.3 front and rear.
Re: for 185/205 5x114.3 hub change - warning lots of pix(no
Postby tubasteve » Sun Mar 11, 2012 8:06 pm
tubasteve
Postby temperacerguy » Sun Mar 11, 2012 9:17 pm
Galaxy Quest.
Very sexy work. I like your "bolt on" approach.
This opens up alot for us.
Thank you!
temperacerguy
Postby abraxxa » Sun Mar 11, 2012 9:52 pm
Are you sure this also works for the ST205 because the brake rotors are much larger and not floating.
facelift ST205
abraxxa
Postby tubasteve » Mon Mar 12, 2012 2:06 am
abraxxa wrote:Are you sure this also works for the ST205 because the brake rotors are much larger and not floating.
Must have gotten deleted? It was in red "brakes only work for 185".
I am currently working to solve st205/165 a well.
tubasteve
Postby dragstang86 » Mon Mar 12, 2012 2:46 am
tubasteve wrote:
dragstang86 wrote:If you could also provide the I.D of the rear rotor, where the parking brake goes that would be a huge help. So in summary:
1. The rear rotor I.D. - parking brake
2. The rear rotor offset from hat face to rotor face
3. The Highlander hub diameter.
Thanks a bunch! :D
Damn it, i got sick last night and keep forgetting i have the numbers and pictures. I'll upload tonight.
Thanks for the pictures. The numbers would be great when you get a chance. Will help me figure out a Wilwood hat/rotor combination that I can use for the back with the Highlander hubs.
92 All trac
dragstang86
Postby tubasteve » Mon Mar 12, 2012 4:30 am
Yeah, forgot, wife got a call to goto dinner with her family. I get in early tomorrow, and I'll measure as much as i can
tubasteve
Postby lumbercis » Mon Mar 12, 2012 5:29 am
Sorry, I think I need things spelled out a bit more clearly.
Fronts:
Spindle: ST185 unmodified
Hubs: Rav4 ????-????(years)
modifications needed: none
Rotor: (Front) Camry (any trim) 2002-2006 (based on this cross reference http://www.toyodiy.com/parts/xref?s=435 ... 6040&mU=on)
modifications needed: shave inside (hub side) of rotor -2.85mm. shave rotor diameter????
Brakes: ST185 unmodified
Rears:
Hubs: Highlander (any trim) 2001-2003, Lexus RX300 1999-2003
modifications: none
Rotors: (Rear) Highlander (any trim) 2001-2003, Lexus RX300 1999-2003
modifications: none
Parking brakes: ST185 or Highlander unmodified
Please correct as necessary.
J.
Caldina powered...
lumbercis
Postby tubasteve » Mon Mar 12, 2012 4:36 pm
Fronts:
Hubs: Rav4 96-2000
Rotor: (Front) Camry (2.4/3.0) 2002-2006 (based on this cross reference http://www.toyodiy.com/parts/xref?s=435 ... 6040&mU=on)
modifications needed: shave inside (hub side) of rotor -2.85mm. shave rotor diameter not needed
Rears:
Hubs: Highlander (awd only) 2001-2003, Lexus RX300 1999-2003
modifications: none
Rotors: (Rear) Highlander (awd only) 2001-2003, Lexus RX300 1999-2003
modifications: none
Parking brakes: ST185/Highlander unmodified(are the same)
tubasteve
Postby DeeCee » Tue Mar 13, 2012 7:26 am
Thought I'd just say, that this is a top notch conversion. I believe that is one that definitely took a little longer than normal to get right. Congratulations.
Of note, this now opens up the st205 front brake kit using the altezza/supra 296x32mm disc with standard caliper location. I think some investigation is required ;)
Of course this now renders the st205 rear caliper upgrade null, unless people don't mind redrilling the PCD and opening up the centre bore to fit the hub. It is possibly worth it as rear brake disc changes are minimal :)
Great work! This conversion will be spread worldwide i'm sure :)
Cheers
Dave
DeeCee
Postby tubasteve » Tue Mar 13, 2012 8:41 pm
On the rears i'm looking into a bolt on rotor, just waiting for it to show up.
tubasteve
Postby abraxxa » Tue Mar 13, 2012 9:36 pm
I don't want to lose my Endless rotors because of this :doh:
facelift ST205
abraxxa
Postby alltracshoak » Wed Mar 14, 2012 7:20 pm
so as reading...what needs to be changed is just the hub to make it 5x114.3 ..uses st185 bearings/axles/spindle but uses different rotors due to the changed from 5x100. if so, i believe it will be able to adapt to the porsche brembo due to the same location of everything besides the bolt pattern
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby CMS-GT4 » Wed Mar 14, 2012 7:54 pm
If your using sti rotors the issue is the center bore. You can buy the same sized sti discs in 5x114. This problem is the center bore is smaller. So either you machine that larger, or you get the spindles machines down.
Postby alltracshoak » Wed Mar 14, 2012 8:11 pm
So the rav 4 spindle has a bigger center hub than the st185???
current:
90 st185
GT4 AWD
alltracshoak
Postby tubasteve » Wed Mar 14, 2012 8:18 pm
Yes, i'm working on that with multiple members.
-Jr
tubasteve
Return to FAQ / Archive
