Switch to full style
Post a reply
Standard gauge readings thread
Sat Jul 14, 2012 4:05 am
So I don't know what to label this but I want to know what readings/numbers I'll see when I install my gauges so instead of starting individual threads I'm starting one to have all them labeled to help me and others.
So help me out guys and add to the list so we can make it helpful to others like me. :)
- Wideband
idle 14.3-15, under full stock boost 10-12 depending
- Coolant temp in F
- Oil pressure
- Fuel pressure
- Volts
- EGT
- Transmission oil temp
- Oil temp
So this should be a good start. Hope to see someone fill it in for me and others. Thanks guys and any other things to add relating the topic then feel free to do so
Re: Standard gauge readings thread
Sat Jul 14, 2012 6:38 am
you should specify if u want figures from stock cars or modified cars.
Sat Jul 14, 2012 9:51 am
I think it would be fair to assume that the "Standard" in the title refers to "stock" cars.
Sat Jul 14, 2012 5:05 pm
Yes please just the stock numbers to lightly modded. Such as exhaust? Intake , stock boost, top mount intercooled,
Personally have all this and a 56mm rad and dp but other then maybe 20hp from all the little things I'm still stock. Want these to help justify if and when numbers are close to listed numbers or far from it and to look further into things
Tue Jul 17, 2012 11:56 am
Anyone have mixed answers for me atleast?
Post a reply
