Switch to full style
Post a reply
Timing belt
Wed May 08, 2013 4:50 pm
Does the st185 timing belt,water pump, front and rear main oil seal the same as the st205?? Thanks
Re: Timing belt
Wed May 08, 2013 4:54 pm
timing belt/water pump are not the same.. front n rear main are the same
Re: Timing belt
Wed May 08, 2013 5:28 pm
Where can i get the st205 timing belt and water pump. Thanks
Re: Timing belt
Wed May 08, 2013 5:29 pm
Oh ya and whats the difference between 185-205
Re: Timing belt
Thu May 09, 2013 9:58 am
205 has a bigger pump assembly an timing belt on 205 has 2 less teeth!! i learned the hard way using a 2nd gen timing belt on my 215 swap!! blew 3 ringlands!! lithia toyota can get them for you. the 205 timing belt is $100 shipped from lithia toyota.
Re: Timing belt
Thu May 09, 2013 1:06 pm
oka wrote:Where can i get the st205 timing belt and water pump. Thanks
I bought my belt on amazon (HKS) and the water pump from http://www.tcbparts.co.uk/
You can get all the parts from TCB also...i just wanted a stronger belt, they sell nippart also which is as good as OEM. http://www.nipparts.com/
Re: Timing belt
Thu May 09, 2013 1:16 pm
Actually I believe i bought the kit but didnt use the belt. If your interested let me know I can dig it up.
Re: Timing belt
Thu May 09, 2013 1:22 pm
Thank you. Ill let u know about your timing belt
Re: Timing belt
Thu May 09, 2013 3:36 pm
Another question. I have a hks cam gear,hks flywheel and clutchmaster for st165. Will those fit st205?? Thanks newbe here. Lmao
Post a reply
