[FAQ] Celica GTS radiator in Alltrac?
• Page 1 of 1
My alltrac has been under serious reconditioning all because I blew my radiator and i took advantage of it bein in the shop, anyways though can a gts radiator fit an alltrac? I head it did and all you had to buy was the fan drops.
Thanks
Dan
Thanks
Dan
Indy3sgte - Club Member
90-93 Celica GTS radiators will fit. The fan will not mount as exactly as OEM, but in the end you can get it to work.
ST165, then ST165, then ST185, then ST165.
Yes I've been there.
alltrac.net - Site Admin
92AllTracTurbo wrote:I believe 3 of the 4 nuts or bolts that hold the fan fit with the GTS radiator.
Yes, that is correct. I had my gts in my 93 for a lil while. You can even move the lil nut so all 4 bolts work. Everything else is a direct bolt-in.
alltracman78 - GTFour God
All Trac Radiator
I've got an slightly modified '88 All Trac. The radiator is shot; The cooling fin tubing is breaking lose in several places where it fits into the bottom tank. Will the GTS radiater also fit into the ST 165?
PS, Unlike most cars, instead of aluminum, I noticed my radiator is made of copper and brass. That would be a lot more efficient at heat exchange than aluminum.
- Greybeard
• Page 1 of 1
