[FAQ] Celica GTS radiator in Alltrac?
Postby Indy3sgte » Sun Aug 22, 2004 12:23 am
My alltrac has been under serious reconditioning all because I blew my radiator and i took advantage of it bein in the shop, anyways though can a gts radiator fit an alltrac? I head it did and all you had to buy was the fan drops.
Thanks
Dan
Indianapolis, IN
1990 ST185
Rebuild Pictures (UPDATED!! AGAIN!)
Indy3sgte
Postby Gary » Sun Aug 22, 2004 1:45 am
I remember that the heavy duty radiator for 5th gen Celica GT-S fits fine on ST185. I think it has an extra tranny cooler at the bottom that you need to cap it off.
93 ST185
Gary
Postby Indy3sgte » Sun Aug 22, 2004 2:08 am
so normal stock wont fit? where can i get a heavy duty one?
Thanks
Dan
Indianapolis, IN
1990 ST185
Indy3sgte
Postby Gary » Sun Aug 22, 2004 2:37 am
Have you tried radiator.com?
93 ST185
Gary
Postby alltrac.net » Sun Aug 22, 2004 3:03 am
90-93 Celica GTS radiators will fit. The fan will not mount as exactly as OEM, but in the end you can get it to work.
ST165, then ST165, then ST185, then ST165.
Yes I've been there.
alltrac.net
Site Admin
Postby pog0 » Sun Aug 22, 2004 6:51 pm
I believe 3 of the 4 nuts or bolts that hold the fan fit with the GTS radiator.
Kevin Hall
92 Gray ST185 - Sold
01 GGP IS300 - Sold
06 GG Evo IX MR
San Diego
pog0
Postby LTJBOY18 » Thu Aug 26, 2004 8:08 pm
Does anyone kno how is the performance radiator that is sold on 935 motorsports.
LTJBOY18
Postby pog0 » Fri Aug 27, 2004 7:13 pm
Try emailing them and asking.
Kevin Hall
01 GGP IS300 - Sold
06 GG Evo IX MR
San Diego
pog0
Postby alltracman78 » Mon Sep 13, 2004 1:25 am
92AllTracTurbo wrote:I believe 3 of the 4 nuts or bolts that hold the fan fit with the GTS radiator.
Yes, that is correct. I had my gts in my 93 for a lil while. You can even move the lil nut so all 4 bolts work. Everything else is a direct bolt-in.
All Trac Radiator
Postby Greybeard » Tue Nov 02, 2004 7:01 am
I've got an slightly modified '88 All Trac. The radiator is shot; The cooling fin tubing is breaking lose in several places where it fits into the bottom tank. Will the GTS radiater also fit into the ST 165?
PS, Unlike most cars, instead of aluminum, I noticed my radiator is made of copper and brass. That would be a lot more efficient at heat exchange than aluminum.
Greybeard
Return to FAQ / Archive
