185 ABS REMOVAL**new pics**
Postby silence » Tue May 03, 2005 1:22 pm
It works!
You CAN swap the ABS lines with the front brake lines from a non-ABS Celica ST.
All you need are the brake lines to the left of the master cylinder, the proportioning valve, and a 3 way valve. The line that goes to the driver's side brake is the same in both cars. Here is a list with prices for those who want to get the parts from a dealer...I picked up everything from my local junkyard for $15.
PARTS
47314-20360.....$20.55 Line, passenger to P-valve
47311-20710.....$13.83 Line, P-valve to Master Cyl
47312-20190.....$ 4.49 Line, master cyl to 3-way
47315-20490.....$ 9.29 Line, driver to 3-way (same)
47313-20480.....$13.46 Line, P-valve to 3-way
47150-20140.....$195.03 Proportioning valve
90413-10182.....$13.75 3-way
**You do not need any lines that go to the rear of the car, they are the same**
06 WRX, 90 Celica Alltrac & 88 BMW TURBO 325is
http://www.youtube.com/watch?v=Ei5P9LfLRdg
silence
Postby RIalltrac » Tue May 03, 2005 1:24 pm
somone sticky this, good info to have. Finally someone documenting what we need, Thank You.
Chris - 90 ST185
RIalltrac
Images: 2
Postby TomsGT4 » Tue May 03, 2005 1:54 pm
Nice job!
Did you take any pics of the swap?
I'm trying to invision how everything was routed.
Tom
1990 ST185
1990 Corolla SR5
TomsGT4
Postby TomsGT4 » Tue May 03, 2005 1:56 pm
Also, we have to move this out of the Club Chat forum or it will be deleted in 30 days. :(
Tom
1990 ST185
1990 Corolla SR5
TomsGT4
Postby OlyST185 » Tue May 03, 2005 1:58 pm
this is sweet, do you have any pics of the installation, i guess those part from a non-abs celica GT/GTS would work right?
-Oly (Montreal)
3SGTE'S POWER, 4WD SUPREMACY
[img]http://olyst185.multimania.com/turbo4wd.jpg[/img]
-ST185 1990 Black. RC/CS Conv.
OlyST185
Postby silence » Tue May 03, 2005 1:59 pm
thanks, I will take some pics...
Who can move it?
silence
Postby b00staholic » Tue May 03, 2005 2:47 pm
Thanks Silence, that is really helpful.
A writeup on the install or pics would be great too.
One question though: for those of us with our engines still in the car, is removing ABS possible? Will I be able to get all of the lines and the actuator out??
If not, to what extent can ABS be "removed"? like would I be able to remove all the speed sensors and swap over the new lines but leave the actuator in place, etc.
Thanks!
Vincent
'90 ST185
b00staholic
Postby froussemaite » Tue May 03, 2005 4:00 pm
Good parts listing... but just to note;
If you save all of the fittings when you remove the ABS you can make your own lines. I did the front-end conversion on my car for under $100CDN.
All that you really need to do is get a 2 Ts, an adjustable brake bias controller and some line.
[edit] I have some good pics of my whole set-up that I will try to post
--Jake
90 ST-185
Nemesis ECU, T04-E 46, 540 inj, 3" Turbo Back
Whitline springs and swaybar, Koni srtuts, full bushings
Removed: ABS, AC, CC, TVIS and More
froussemaite
Postby silence » Tue May 03, 2005 4:39 pm
OK,
I will try to answer most of these questions.
b00staholic:
You can remove your abs with the engine in the car...it will be difficult to get to the proportioning valve, but if you cut/bend the old ABS lines...you can get them out.
The actuator is probably the easiest thing to remove... It has a few bolts on top and one that bolts in from below...you need to remove your windshield washer tank to get to it.
You can leace the actuator in place, but why have dead weight(8 or 9 lbs) in the car if its so easy to remove?...
froussemaitre
you're right, I thought of doing that...but if you can get the parts at a junkyard, it will be a whole lot cheaper and easier.
I'd love to see pics of your setup!
silence
Postby b00staholic » Tue May 03, 2005 4:43 pm
Ok, cool, I'd really like to remove my ABS with the engine in the car. So if I'm willing to mangle the lines in the engine bay, it shouldn't be a problem? I guess no one is really going to be wanting to buy used ABS lines (from the tone on this board at least).
Where exactly is the proportioning valve?
Vincent
'90 ST185
b00staholic
Postby turbo4wd » Tue May 03, 2005 4:46 pm
This has been moved to the FYI/FAQ section so it won't be lost..
Dan
Undercover Moderator
turbo4wd
Postby silence » Tue May 03, 2005 5:06 pm
thanks for moving it!
Mangle them up if you need to...I kept mine in one piece...(easier to do with the engine out) The proportioning valve is on the firewall in the center of the bay, above the steering rack.
silence
Postby rightrac » Tue May 03, 2005 10:48 pm
did u do this on a 165 or a 185?
rightrac
Postby turbo4wd » Tue May 03, 2005 11:25 pm
rightrac wrote:did u do this on a 165 or a 185?
The part number #47150-20140 is for a st185 brake proportioning valve.. Interestingly enough, this is also the same part# for a 1990 V6 Camry..
Dan
turbo4wd
Postby silence » Tue May 03, 2005 11:28 pm
I did it on a 185....and changed the subject heading to reflect that.
Thats good info about the proportioning valve...more options for the junk yarders like myself.
silence
Return to FAQ / Archive
