How do you peform compression test with TMIC still on?
Postby Rick89GTS » Fri Jan 13, 2006 5:03 am
Stubble wrote:Step on the accelerator as well while cranking. I read an extra couple of psi when I did this, and the BGB confirms this is the correct procedure. All spark plugs out.
Yep, good point, forgot about that
Return to FAQ / Archive
