Ok, so last night I was driving and noticed that, occasionally, when I hit the brake pedal, the back lighting for my gauges, and the back lighting for the climate control, basically anything controlled by the dimmer knob, would flick off for a second and then come back on. It didn't happen over bumps in the road or anything, only when I pushed the brake pedal, so I believe it's something to do with the brake light circuit. Anyway, so later on, they went off completely and never came back on. Then when I went to get out of my car, I noticed my power door locks no longer work either.
I tried looking through wiring diagrams, but I can't find the back lighting in any of them. I tried to see what the brake lights and door locks had in common, but the only thing I could find was they use the same ground. I checked that ground and it's clean with no corrosion or anything. I cleaned it anyway for just good measure but no luck. Any help is greatly appreciated! thanks
the car is an 88 alltrac btw
