First of all, The front speakers are much more important than the rears, a nice set of components in the front and stock speakers in the rear will sound great. rear sound is just for fill in. 80% of the sound is the front.
50 watts from an infinity outboard amp is plenty of power for any speaker. those components will rock.
You could use a five channel amplifier also, Just hook up both of your 8" speakers to the 5th "sub" channel and this will see two ohms, and the rest of your speakers will be a 4 ohm load.
you never really want to push interior speakers at 2 ohms, you usually only gain around 40-75% more power but you get 10 times the distortion, I would only use 2 ohm loads on low frequency drivers like your 8" woofers, because the human ear if less sensitive to distortion in this area.
I hope you have a good head unit, Because it seems as if you are buying really nice stuff and a good headunit with a good D/A converter and rca outputs will dramaticly better the sound of an onboard amp. (line level is ghetto) but to each his own.
you could)
1) use those two infinity amps to power you two sets of interiors, and get a seperate two channel or mono amp to run those 8" woofers.
2) sell those 2 infinity amps on ebay and pick up a nice 5 or 6 channel amp to run everything (MUCH easier installation and cleaner setup)
3) I know you said you might not want a sub but a single ten inch or 12 inch sub in a good box will blow those 8" woofers away ( the door just isn't a good enclosure) then you could install that component system in the front and leave the rears stock. Use one of those infinity amps to power the fronts. your headunit to power the rears. And bridge the other infinity amp to run a single sub at two ohms, so probably giving it 150 watts. (if the sub is a 4 ohm sub). This would sound really good and you wouldn't have to spend much else.
Just a few options
Also Crutchfield is expensive for amplifiers or most anything actually, ebay is the cheapest, just look for a good 5 or 6 channel amp. Infinity makes good stuff though. Just found that 6channel infinity for 219.00 "buy it now" on ebay.
If you want anymore info on anything car audio feel free to pm me, (sorry for rambling but car audio if my thing), I love doing that stuff.
