JDM ST185 mirror wiring.
Postby SuperWhite92 » Tue Sep 21, 2004 10:34 pm
I was wondering if anyone had done this, and could tell me a few things:
Where is the relay box located?
Anyone have a basic write-up?
Does the harness behind the switch plug into and work with the JDM mirrors?
Shaun
SuperWhite92
Postby GMan » Tue Sep 28, 2004 2:01 am
Where is it Stock ? The USDM do not have one.
For Euro, Ozzie. JDM, the relay is under the steering wheel.
I have not looked if USDM have a bracket for the relay.
You can mount one anyhwere your heart desires and the wires reach.
It was posted on the old board.
Maybe Roo has the wiring diagrams ?
He is the Only person that got them working ?
You Need the JDM switch which has the "Retract" button.
Unless you want to just hook up your Own cool momentary-
On switch. Both plug in the harness. On the US switch
there is Just one pin missing that sends a retract signal.
All from memory. I have the mirrors, but never hooked them up.
Regards
GMan
Postby thkohlb » Tue Sep 28, 2004 3:47 am
any idea if that is a positive or negative switch to retract the mirrors?
Tk 1992 Celica All Trac
thkohlb
Postby SuperWhite92 » Sat Oct 02, 2004 9:08 am
I have the switch that has the retract button, as well as the mirrors, and the relay with a pigtail, and what all of the colored wires mean, but the stock harness that plugs into the switch is the same shape and has the same no. of prongs as the jdm one does. What i really wanted to do was take it and replace that switch, then cut the wires, to put them into the relay, but im not sure of where the relay sits in the circuit or anything. Does it go like this? And the other thing is where does the wires for the relay go? it only has the one plug on it.
Mirror--Relay--Mirror
Switch
Shaun
SuperWhite92
