Blitz Turbo Timer Install in ST165
Postby Rick89GTS » Sun Sep 26, 2004 1:49 am
Hey guys,
Whoever's hooked up a Blitz Turbo Timer in their ST165, can you help me out?
1) On the car, which wire did you guys draw your 12V constant power from?
2) On the car, there are two ignition sources, IG#1 and IG#2. Which one do you use?
Appreciate any help, thanks :)
Rick89GTS
Re: Blitz Turbo Timer Install in ST165
Postby smc252 » Thu Nov 11, 2004 2:01 am
It was a while ago, but going from memory...
1) Black + red stripe should be the constant 12v
2) Ignition #2
1988 All-Trac
(Rotting away, fiending for a tranny.)
1986 Celica GTS
(GT3071R forced 3s-gte + autronic smc)
smc252
Postby Rick89GTS » Thu Nov 11, 2004 9:51 pm
Hey thanks for the help.
Looks like I've got a Blitz harness on the way, so hopefully I won't have to hard-wire it now. I wasn't looking forward to doing that.
Appreciate your help just the same though, Cheers :D
Rick89GTS
Postby Rick89GTS » Sat Sep 08, 2007 12:52 am
Thought this Blitz MSTT installation might help some others:
Rick89GTS
