Momo sterring wheel
Momo sterring wheel
Postby gtfourever » Sat May 27, 2006 5:48 pm
Just curious if I have to ditch my cruise control to bolt on the wheel. If so, does anybody have a aftermarket sterring wheel and was still able to use the cruise control, I mean did you mount it another location? Or does it have to completly go.
gtfourever
Postby bigacuralvr » Sun May 28, 2006 4:09 pm
I would also like to know!! Also, where did you get your steering wheel adaptor? Do you have any pics of it? Is it a spline type??
Thanks,
Brett
1990 Celica AllTrac Turbo - Sold to a new home :(
1999 Yukon - Family Mobile
2000 Dakota Club Cab - Snow Machine
2006 Scion xB - Pimp Box - HP2BSQR
2000 GSXR - Go Fast on 2 Wheels
bigacuralvr
Postby gtfourever » Sun May 28, 2006 8:06 pm
I got a momo hub off ebay for any 90-93 celica
gtfourever
Postby theUNYTEDone » Mon May 29, 2006 10:44 am
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Re: Momo sterring wheel
Postby gtfourever » Sat Jun 03, 2006 9:40 pm
gtfourever wrote:Just curious if I have to ditch my cruise control to bolt on the wheel. If so, does anybody have a aftermarket sterring wheel and was still able to use the cruise control, I mean did you mount it another location? Or does it have to completly go.
I got the cruise to work with the momo steering wheel.
Just used the eyelets on the cruise control switch and screwed it under my steering wheel. Works for me...
gtfourever
Postby =cJ= » Sun Jun 25, 2006 11:40 pm
gtfourever wrote:
Y'know, you could mould a blister out of 'glass for it under there and it could look pretty good...
Though I guess you don't see it that well anyway.
1990 Celica GT-4 ST 185
=cJ=
Postby 3DZ » Mon Jul 03, 2006 4:36 am
how did you guys make the horn work?
3DZ
Postby =cJ= » Tue Jul 04, 2006 4:51 am
The momo hub for the celica comes with the rotating contacts for a horn, and you use a horn centre button with a wire which clips to a contact on the hub and then the horn button fits into the steering wheel.
=cJ=
Postby maxaud » Tue Jul 04, 2006 5:31 pm
I had a quick question... sorta off topic here a lil'... did the st185rc have cruise control when it was fit'd w/ the momo wheel?
-Dustin
maxaud
Postby 3DZ » Tue Jul 04, 2006 7:48 pm
CJ do you have pictures of this. cause the only thing i got is the Air bag cricle rotating donut and if i leave that on the momo hub adapter will not fit.
3DZ
Postby CMS-GT4 » Tue Nov 01, 2011 4:34 am
Bump, what is this about a hub allowing the hub to work?
Postby underscore » Tue Nov 01, 2011 4:42 am
when I put a MOMO hub and wheel on my 92 GT-S I was able to keep the cruise lever, not that cruise works anyways.
Postby CMS-GT4 » Tue Nov 01, 2011 5:03 am
I meant to type for the horn to work. I need a horn in this car bad.
Postby underscore » Tue Nov 01, 2011 5:29 am
the hub does allow the horn to work, it passes a wire through which gets hooked to the horn button on the wheel. Worst case scenario you could order up a button holder plate from NRG and wire those buttons as horn buttons.
Postby CMS-GT4 » Tue Nov 01, 2011 6:57 pm
My hub has no holes to pass a wire through. I suppose I could drill one, but either way I need to look at my option soon.
