Where to put FCD?
Where to put FCD?
Postby busdriver » Fri Oct 22, 2004 4:36 pm
I was just wondering what the easiest place to wire in the FCD is? I was just going to make my own, but I don't know where to wire it into the car. Any help would be appreciated.
Jake
90 st185
needs tlc
busdriver
Postby enzytebob » Fri Oct 22, 2004 4:52 pm
there are 2 ways: either right next to the ECU (behind the console box via the passenger side) where you splice into specific wires or the boost pressure sensor connection on the firewall. You would splice into some of those wires, too.
I found the link.... this is to connect to the boost pressure sensor electrical connection at the firewall.
http://toymr2.tripod.com/fcd.html
go the install part.
hth :wink:
enzytebob
Postby busdriver » Fri Oct 22, 2004 6:08 pm
Maybe I'm just being retarded here but does anyone have a pic of where that boost pressure sensor connection is on the firewall?
Jake
90 st185
needs tlc
busdriver
Postby enzytebob » Fri Oct 22, 2004 7:37 pm
This is for an MR2 but you'll be able to figure out what and where it is on the Celica.
The label on it that says "sensor assy-turbo pressure" .
It only has one hose,(this is the boost sensor) and one electrical harness. You want to splice into the electrical harness...
http://mr2.noegruts.com/engine/engine.htm
Go to the above link and click on the first picture to get a more detailed view.
enzytebob
Postby busdriver » Fri Oct 22, 2004 9:18 pm
Excellent pic, thanks.
Jake
90 st185
needs tlc
busdriver
