How do you do replace tail lightbulbs? Do you take off the exterior tail light lenses, or do you go through the interior? If you remove the lens, how is this done? I see only one screw at the top (in the area that the trunklid would cover when closed).
The specific one I want to remove is the left rear that's actually on the side of the car.
