List of 8" woofers that fit the door panels
Re: List of 8" woofers that fit the door panels
Postby toayoztan » Sun Apr 10, 2011 1:25 am
http://cgi.ebay.com/2-CADENCE-FX8M4-8-5 ... 5193a0a129
Eh? What about these?
I got a free cadence sub 12" from someone I never installed (yet). What's the deal with cadence? The frequency seems to be a bit high for midbass drivers?
These have a mounting depth of 2.5"!
Here are the specs, listed from the ebay site:
Features:
8” Open Basket Midrange Speaker
Kevlar Reinforced Black Pulp Cone
Treated Cloth Accordion Suspension
Linear Progressive Conex Spide
Acrylic Bullet Phase Plug High SPL Design
High Tinsel Expanded Steel Basket
Super Slim Design facilitates Door Installations
Oversize 1.5” High Temperature CCAR Voice Coil
90 oz Magnet Structure Weight
Includes Wire Mesh Grill
Prewired with Bass Blocking Capacitor
Specifications:
RMS Power Handling: 125 Watts
Peak Power Handling: 250 Watts
Frequency Response: 100Hz-11KHz
Sensitivity: 102dB @ 1w/1m
Impedance: 4 Ohms (Also available in 8 ohm)
Mounting Depth: 2.6”
Weight: 4.5 pounds Each
Magnet Diameter 4.75”
Magnet Thickness 3/4”
Mounting Depth 2.5”
TS Parameters:
FMS: 93.1 Hz
QMS: 11.75
QES: 0.82
QTS: 0.76
RES: 6.9 Ohm
RMS: 0.7 kg/s
CMS: 0.20 mm/N
MMS: 13.7 gr
NREF: 0.92 %
BL: 4.9
SPL: 102 dB
VAS: 12.91
RE: 3.4 Ohm
RP: 20.1 Ohm
LP: 5.1 mH
GP: 936 1uF
LE: 0.3 mH
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby toayoztan » Sun Apr 10, 2011 1:34 am
From Cadence, there's also these:
http://www.cadencestore.com/ProductCart ... roduct=581
http://www.cadencestore.com/ProductCart ... roduct=583
And if I do consider these (or anything else)...do I go with 2, 4, or 8 ohm? Not sure if I'll be running stock amp for now or just upgrade the amp now (with crossovers).
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby toayoztan » Sun Apr 10, 2011 1:44 am
Sorry for posting all these links (don't even know if Cadence is good lol), but here are some I found of their CVL series with a mounting depth of 2.13"!
http://www.cadencestore.com/ProductCart ... roduct=598
It seems people either don't know of cadence (and thus spit out ignorant reviews) or said they are decent and have had some following time to time in the audio enthusiasts (especially with subs/amps)...I don't know (it was only a quick 5 minute research).
In any case, if they seem decent, I may just try these in my doors. Although, I'm still curious why the range is so high (up to 11khz vs the usual 500hz or so for the other midbass drivers...)...any ideas why this might be?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby turbo4wd » Thu Apr 14, 2011 7:57 pm
toayoztan wrote:So ssmb8 are no longer in stock, anywhere that I can find. What have you guys been replacing them with?
I want a midwoofer, not a midrange, in there.
Does Kicker have anything comparable? They have the COMP VR which seems comparable in specs, but the mounting depth is almost 2" deeper. The COMP VT is supposed to be the "shallow" counterpart to the VR, but the frequency seems to be lost some @ 25-350Hz vs VR's 30-500Hz (like the SSMB8).
What do you guys think? I don't know how much room is back there for the magnet (it appears only the front most part of the door has to be cut/grinded down for the SSMB8, not the rear metal portion that is deeper). But it seems like the CompVT may be the way to go now...
SSMB8 specs
http://www.crutchfield.com/S-0iqsA4K85V ... SSMB8.html
CompVR specs
http://www.crutchfield.com/p_2061CVR82/ ... rch=compvr
CompVT specs
http://www.crutchfield.com/S-OUk8EVykIV ... CVT84.html
Thanks
Bryan
I just installed these recently - they're the current version of the CompVT's you linked:
http://www.sonicelectronix.com/item_21926_Kicker-CVT84-10CVT84.html
There isn't an issue in terms of mounting depth, you'll have room. The issue is the magnet has a very large diameter (compared to stock) and the wire terminals are spaced such that you'll have to cut out the back of the Livesound panel as well as cutting into the door - but once you get that done, they sound great.
Dan
Undercover Moderator
turbo4wd
Postby toayoztan » Thu Apr 14, 2011 11:53 pm
So no issues with the fact they aren't meant for free air? Or does the live sound box do a decent job of being the "box"?
I'd like to get the ones you have, but am thinking of those Cadence's also..
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby turbo4wd » Fri Apr 15, 2011 2:25 am
toayoztan wrote:So no issues with the fact they aren't meant for free air? Or does the live sound box do a decent job of being the "box"?
Bryan
It's not specifically designed for sealed - its fine for both applications. And the Livesound box is nothing more than a large bracket. The door acts as a large vented enclosure.
Dan
turbo4wd
Postby toayoztan » Fri Apr 15, 2011 3:47 am
Cool, so not much more cutting on the actual door itself (I don't mind cutting into the plastic box) vs the SSMB8?
I'll probably pick these up then.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby turbo4wd » Fri Apr 15, 2011 4:55 am
toayoztan wrote:Cool, so not much more cutting on the actual door itself (I don't mind cutting into the plastic box) vs the SSMB8?
Bryan
The CompVTs are totally different - the terminals are such that you'll have to cut into the door. More than the SSMB8's. The SSMB8's terminals are on the sides so its no big deal - the CompVT's are on the bottom and spread apart from each other - I initially cut a little just like in the pictures, but the terminals kept shorting out on the door so I had to go back and make the following cuts to make it work:
Dan
turbo4wd
Postby toayoztan » Sun Apr 17, 2011 7:35 pm
Well...these were dug up. Kind of pricey, yeah?
http://cgi.ebay.com/KICKER-04SSMB8-CAR- ... 5d2e60c282
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby RedCelicaTRD » Tue Apr 08, 2014 2:41 pm
Just about 3 years later......
Anyone seen these before?
http://www.powerbassusa.com/s-804-s-804d-8-subwoofer
3.5" Mounting depth. $60 on eBay.
Reason: Updated link
Postby RedCelicaTRD » Sun May 11, 2014 9:05 pm
I ordered a Kenwood KFC-XW800F and will test it out when it arrives. Mounting depth is 2-3/4", but the frame looks like it might cause some problems.
Postby RedCelicaTRD » Mon May 26, 2014 8:09 pm
Well, the Kenwood doesn't even come close to fitting. Good thing it fits my Jeep!
Postby tubasteve » Sun Oct 04, 2015 3:52 am
I know I'm reliving the past, but just an update to whats available.
These fit, small cut in the door/plastic housing
tubasteve
