List of 8" woofers that fit the door panels
Postby tweekgt4 » Mon Feb 14, 2005 5:25 pm
The GTSs came pretty loaded. They pretty much have all the options a standard ST185 would have except of course the awd 3sgte.
Leather, sunroof, system 10, widebody, climate control, fogs, power driver seat, power mirrors/windows, power antenna, 3 piece spoiler, cruise...
Did I leave anything else out?
oh wait.. the GTS does not have the steering column pop up.
1999 Volvo V70R, Laser Blue
2001 BMW M5, Titanium Silver
http://www.brsf.net
tweekgt4
Postby MARLON1211 » Mon Feb 14, 2005 6:02 pm
Cool, thanks.
I hope the woofer fits w/ no problem, now i have to find out if the head unit will work on the subs. I heard that it might nott work and needed to have anither wire harness to make it work.
SO BE IT
MARLON1211
Postby tweekgt4 » Mon Feb 14, 2005 6:35 pm
you will need to cut/enlarge the hole of the plastic trim that the stock woofer mounts to.
if you are running an aftermarket headunit, the woofers will not work anymore. you can run a cheapy 2 way amp with crossover and run new wires to the subs or connect the wires from amp into the subwiring in the passenger side kickpanel... i forget the colors exactly but they were either blue or purple wiring...
http://www.brsf.net
tweekgt4
Postby MARLON1211 » Mon Feb 14, 2005 8:42 pm
do you have a step you can give me to make my Subs work.
Any info will help. Thanks
SO BE IT
MARLON1211
Postby tweekgt4 » Sat May 28, 2005 5:07 am
kinda late reply but why doesn't your subs work? did you change the head unit?
MARLON1211 wrote:do you have a step you can give me to make my Subs work.
http://www.brsf.net
tweekgt4
Postby celicat93 » Sun May 29, 2005 7:30 am
Yeah, the first Celica I ever test drove was a GTS fully loaded, including System 10 But it was an automatic (slooooooow) and rock chipped to hell with some really nasty touch-up's so I passed on it (thank god)
celicat93
Postby RafaCalde » Tue Jun 14, 2005 9:53 pm
would these fit without having to grind anything away?
http://www.crutchfield.com/S-HQiJ81CtGq ... subwoofers
RafaCalde
Postby gt4play » Fri Jul 29, 2005 5:12 pm
2of81 wrote:I have a 8" MB quart mid woofer that fit perfectly. About 2 years ago on ebay they had 8's 4's tweets and crossovers for $300.
I bought the same kit. No cutting required. Sound great.
gt4play
1988 ST165 [<23k miles]
1993 ST185 [my baby]
1993 Supra TT Hardtop [my other baby]
1994 MR2T [back together]
2001 Tundra Ext Cab, V8 [work horse]
2010 Highlander Limited [family vehicle]
gt4play
Postby CelicaAllTrac92 » Tue Aug 16, 2005 3:09 pm
My Kicker RMB8 installation pics:
http://bama.ua.edu/~burns007/kickers/
92 All-Trac
Photo Album
CelicaAllTrac92
Kicker SSMB8 8" Midbass Drivers 04SSMB8
Postby Greg_Peddle » Fri Sep 16, 2005 6:49 pm
http://www.sonicelectronix.com/item_3020.html
are these the new model replacing the rmb8's
they seem to have a smaller mounting depth 2.25 . anyone try these yet thinking about getting a pair for my all trac
Greg_Peddle
Postby tweekgt4 » Thu Dec 08, 2005 7:04 am
here's a little tip to cut the plastic mount to fit bigger magnets...
get a drill bit and a drill.
you can use the drill and carve out the hole needed to fit the new woofers. drill in, and then go around in a circle cutting the plastic away. it sure beats using a hacksaw. a dremel with a drill bit will work, too. a cutting wheel requires too much work.
http://www.brsf.net
tweekgt4
Postby Toxygene » Tue Dec 13, 2005 9:26 pm
Has anyone tried to fit 6x9s in there like the infinity 3 way Kappa 6x9s?
Toxygene
Postby 92 All-Trac » Wed Jan 04, 2006 6:22 pm
Am I going to need a crossover to hook up different speakers in the door?
Josh
1992 ST185
92 All-Trac
Postby tweekgt4 » Wed Jan 04, 2006 7:33 pm
92 All-Trac wrote:Am I going to need a crossover to hook up different speakers in the door?
if you're goingto put an 8" sub, you will need a some sort of filter to filter out the highs.
http://www.brsf.net
tweekgt4
Postby tweekgt4 » Wed Jan 04, 2006 7:47 pm
to add to this...
the 8" door sub speaker wiring can be found in the passenger side kick panel (at least in my 91 st185).
you'll should see two sets of wires, some thin and thick ones.
the sub speaker wires should be wrapped in a black tubing (like the cigarette lighter wiring) and the pair you are trying to find is the thick wires.
look for a solid blue with gray dots and a solid light green with gray dots.
http://www.brsf.net
tweekgt4
