List of 8" woofers that fit the door panels
Postby 92 All-Trac » Thu Jan 05, 2006 3:09 am
Cool, thanks.
Josh
1992 ST185
92 All-Trac
Postby toayoztan » Fri Mar 10, 2006 7:05 am
I dont' think it was answered yet, but..has anyone measured or knows the stock mounting depth?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby GT-Four » Fri Mar 10, 2006 1:54 pm
tweekgt4 wrote:The GTSs came pretty loaded. They pretty much have all the options a standard ST185 would have except of course the awd 3sgte.
Leather, sunroof, system 10, widebody, climate control, fogs, power driver seat, power mirrors/windows, power antenna, 3 piece spoiler, cruise...
Did I leave anything else out?
oh wait.. the GTS does not have the steering column pop up.
The GT-S has the auto tilt away steering column as well. So does the GT. Unsure about the ST.
GT-Four
Postby daveryan » Fri Mar 10, 2006 1:55 pm
FWIW, I don't have the exact measurement :doh: but here's my replacement next to the stocker
Dayton DC200-8 on left, stocker on right
The Dayton speaker shown has a mounting depth of 3.75 inches, and the plastic had to be cut to fit it.
So stock is maybe 3-3.5 inches :shrug:
1990 ST185
daveryan
Postby Toxygene » Fri Mar 10, 2006 4:17 pm
Hey Daveryan does the stock speaker have any specs written on it like impedance, or even sensitivity? Also, am I to understand that even though the amp is powering those Subs that the amp has no internal crossover and all the speakers are pretty much being given a full range of frequencies?
Toxygene
Postby daveryan » Fri Mar 10, 2006 9:04 pm
My stock subs are at my dad's house - far away. I always assumed the stock amp did have internal crossovers - at least for the subs. I think the F/R mids and tweeters have external, passive crossovers, since all 8 of those drivers work when you use the hidden non-system 10 harness, which only has 4 connections - front L/R and rear L/R. I can verify the stock subs do not have any passive crossovers mounted next to, or on them. You shouldn't need to add a crossover if you are just replacing the subs. If you replace the amp however...
Anyway, if you're unsure about high/mids in the stock subs, just play some appropriate material and stick your ear down there!
1990 ST185
daveryan
Postby Toxygene » Fri Mar 10, 2006 10:29 pm
:shock: Haha :lol:
Ok I will. But sometimes it's hard to tell what's coming from where.
Toxygene
Postby goldfish » Sat Mar 11, 2006 2:30 am
toayoztan wrote:I dont' think it was answered yet, but..has anyone measured or knows the stock mounting depth?
Bryan
I'm replacing mine with the newer Kicker SSMB8 (which i got for $94 on Froogle). I've got the stockers sitting on the table here and the mouting depth is just a hair under three inches. My new Kicker SSMB8s are just under 2.25 inches...though the magnet is much larger in diameter. I am still installing them, but I bought a 360W 2 channel amp and 4 gauge wiring kit as well along with a bunch of Dynamat Xtreme. I also got a component set of 4" and 3/4" tweaters from MB Quart and a new Pioneer head unit that puts out 27 wats RMS (60 watts peak). Hopefully this wil be a good update to the 15 year old sound. :-)
David G.
'91 ST185
goldfish
Postby Denver_whiteST185 » Mon Mar 20, 2006 5:41 am
How did the Kicker SSMB8 fit. Did you have to modify anything? wires?
^Ted^
Denver_whiteST185
Postby goldfish » Mon Mar 20, 2006 1:41 pm
Denver_whiteST185 wrote:How did the Kicker SSMB8 fit. Did you have to modify anything? wires?
Like the old RMB8 said earlier, you have to cut out the plastic from the speaker holder in the center which isn't a big deal. A couple minutes with a dremmel and it is done. I mounted them last night in the car and I had to take a dremmel with a cutting wheel to the bottom metal piece just below the speaker on the door. I took pictures but dont have them loaded to my site yet. It was minimal amount of cutting and isn't structural to the door at all.
As far as wiring goes, I guess you could use the old wiring, but I'm not. if you are going with speakers that require as much power as the SSMB8's, you should proably use an amp...which means you wont be using any of the stock wiring harness for the stereo. So i ran a new wire to the door speakers which is a thicker wire than stock. I actually cut out all the wires in the car that go from the cd player to the stock amp....they are useless. There are many wires there and none are needed anymore. I do plan to use the stock wiring harnes for the tweaters and the rear speakers, but the rest I'm going to re-do because it will be much simpler. I guess that is easier for me to say because I have my whole car gutted right now, minus the heaadliner and dashboard, because I'm also putting down Dynamat on the doors/trunk to hopefully make the car a bit quieter inside. :-)
I haven't powered them up yet because I only have one door installed, but I'm not discouraged at all at the amount of work to install these. Compared to the engine bay on alltracs, this was easy ;-)
David G.
'91 ST185
goldfish
Postby Denver_whiteST185 » Mon Mar 20, 2006 5:48 pm
damn, i wish i had the cash to do that. :D my stock 8"s are blown, so i was going to just get the speakers, but i think ill hold off and get them installed with an amp.
^Ted^
Denver_whiteST185
Postby Speedy2k » Mon Mar 27, 2006 12:31 am
Goldfish,
what amp are you using? Are you going to run them in 2ohm or 4ohm?
Speedy2k
Postby goldfish » Mon Mar 27, 2006 1:35 pm
Speedy2k wrote:Goldfish,
I'm using a cheap Jensen 360W 2 channel amp - 4 ohm. I dont ever expect to push these speakers anywhere near their max point so I'm not going with an expensive amp. Plus when I was shopping this was one of the lighter weight ones (under 10 lbs) and small enough to fit under the passenger seat. It also had good reviews.
I got the new CD player and front MB Quart component set installed last night and it sounds amazing. I've got the amp wired up and I'm hoping to power it up for the first time tonight.
David G.
'91 ST185
goldfish
Postby goldfish » Mon Apr 03, 2006 4:15 am
I got it all back together last weekend and it sounds great. I'm no longer using the rear speakers at all and it sounds just fine. The rear speaker boxes are pretty heavy - about 5lbs each. I cut out all the old wiring except where it goes into the doors. I really like the new SSMB8s. Here is a small writeup and a few pics of what I did:
http://www.erkou.com/images/interior/speakers.html
David G.
'91 ST185
goldfish
anyone know about these
Postby Greg_Peddle » Thu May 04, 2006 12:01 am
http://www.sonicelectronix.com/item_6876.html#
they dont say midbass driver but there in the midbass driver section
anyone know what these are like i heard bad things about the kickers
Greg_Peddle
