List of 8" woofers that fit the door panels
Re: anyone know about these
Postby goldfish » Thu May 04, 2006 12:57 am
Greg_Peddle wrote:http://www.sonicelectronix.com/item_6876.html#
they dont say midbass driver but there in the midbass driver section
anyone know what these are like i heard bad things about the kickers
Do you know what the dimensions are? They dont list it on that site.
What 'bad things' did you hear about the kickers? From a reliable source or word of mouth through 4 people? I like mine so far and haven't had any problems though I've only had them running for a month.
David G.
'91 ST185
goldfish
yueah
Postby Greg_Peddle » Thu May 04, 2006 11:43 am
no on the same site if u look up the kicker it says that one guy replaced them a couiple times. but they cannt be that bad
and im gonna have to find the dimesnsions for that new one ....
Greg_Peddle
yah
Postby Greg_Peddle » Mon May 29, 2006 12:28 pm
ssmb8 kickers i got a set of them bran new on ebay not used for 140 cdn shipped
i just got them in my door plastic holders and it takes alot of work but its done and it was fun now just gotta trim part of the doorout
note be carefull when taking door trim off there are alotttttttttt of screws in it
Greg_Peddle
Postby theUNYTEDone » Tue May 30, 2006 7:11 am
which amps are all of you running to accomodate the subs?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby goldfish » Tue May 30, 2006 12:16 pm
theUNYTEDone wrote:which amps are all of you running to accomodate the subs?
Goldfish wrote:
Speedy2k wrote:
Goldfish,
what amp are you using? Are you going to run them in 2ohm or 4ohm?
I'm using a cheap Jensen 360W 2 channel amp - 4 ohm. I dont ever expect to push these speakers anywhere near their max point so I'm not going with an expensive amp. Plus when I was shopping this was one of the lighter weight ones (under 10 lbs) and small enough to fit under the passenger seat. It also had good reviews.
I got the new CD player and front MB Quart component set installed last night and it sounds amazing. I've got the amp wired up and I'm hoping to power it up for the first time tonight.
David G.
'91 ST185
goldfish
Postby theUNYTEDone » Tue May 30, 2006 11:30 pm
thanks...i might look into installing some OK subs in my doors, getting a deck, and just replacing the rest of my speakers..no awesome sound system....sound like a pretty cool idea? i think so. heh. im saving this thread for reference. thanks!!!
Nigel in Hawaii
From Hell and Back
theUNYTEDone
yah
Postby Greg_Peddle » Wed May 31, 2006 1:25 am
the speakers in the doors are not subs though. thats the mis concept everyone thinks you can put an 8 inch woofer in there but you cant beacuse its not a sealed box. what you need to put in there is a midbass driver thats what its called. you would be pretty disapointed to install it crank it up and all u see is it shaking and no noise
i have jmine hooked up to my stock amp right now and it sounds fine but i will be upgrading that amplifer eventually but i have other projects ongoing with the car. i only replaced the door mibass drivers because they were blown =)
Greg_Peddle
Re: yah
Postby toayoztan » Sat Aug 19, 2006 10:40 am
Greg_Peddle wrote:the speakers in the doors are not subs though. thats the mis concept everyone thinks you can put an 8 inch woofer in there but you cant beacuse its not a sealed box. what you need to put in there is a midbass driver thats what its called. you would be pretty disapointed to install it crank it up and all u see is it shaking and no noise
Yeah that's what I thought too. I didn't understand why some were talking about putting subwoofers in there. I always called them mid-woofers. I guess mid0-bass drivers is a more appropriate name. In any case, I'm thinking of getting the kickerss too. My driver side is completely blown. And if they sound fine with the stock amp, then i'll probably go ahead and get these now instead of waiting. I can always upgrade amp and other speakers later.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby TheRealDealGT4 » Fri Sep 08, 2006 3:09 pm
I put a pair of Kicker RMB8 subs in my doors, i had to cut away at some of the plastics where the speakers magnet sticks out and some metal off the door, other then that it was a nice fit and they sound amazing
TheRealDealGT4
Postby Toxygene » Thu Sep 14, 2006 4:51 pm
Has anyone tried these Lanzar subs?
http://www.lanzar.com/itempage.asp?MODEL=NEO8
It looks like they wouldn't need as much trimming and the price isn't bad either.
Toxygene
Postby WarTowels » Mon Sep 24, 2007 3:35 pm
Resurrection!
This link was posted in the first post.
http://www99.epinions.com/Legacy_Audio_ ... full_specs
They are sooo cheap, and my stock ones are sooo blown I was thinking about getting them until I can afford something better.
Does anyone have these?
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby Toxygene » Mon Sep 24, 2007 6:13 pm
I've see a few marine speakers as well that are the exact same size as the old speaker. 7 inch speakers:
http://www.clarion.com/us/en/products/2007/marine/speakers/index.html
http://www.alpine-usa.com/US-en/products/product.php?model=SPR-M700
Toxygene
Postby AlltracAllday » Tue May 06, 2008 7:35 am
AlltracAllday
Postby Toxygene » Tue May 06, 2008 8:16 am
That's awesome... I didn't know that Pioneer made that sub in an 8 inch version.
You might still need to trim things but probably not as much cutting. I have the enclosures for the door speakers and short of actually getting a shallow mount 7 inch, I think you'll still need to trim for an 8 to fit.
Toxygene
Postby AlltracAllday » Wed May 07, 2008 2:26 am
Alright awesome I think that is what I am looking at getting then
AlltracAllday
