List of 8" woofers that fit the door panels
Postby WarTowels » Mon Mar 02, 2009 5:24 am
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby GT4RC » Mon Mar 02, 2009 6:28 am
I've heard these are the way to go... except for a 3-way component setup properly crossed over...
http://www.earthquakesound.com/sws.htm
* SWS-8 300 Max
* 2 1/8" mounting depth
* Over 1.5" long throw excursion
* 1.5" aluminum VC (4-ohm)
* MSRP: $173.00
GT4RC
Kicker SSMB8
Postby wyomingtoy » Wed Mar 18, 2009 6:58 pm
I just checked with the ebay seller that I had purchased these from. Last month they had two new pairs for sale. I bought one of the two. Looks like they are out. I would keep checking on ebay.
It was not the mounting depth the was the problem, it was the diameter of the rear of the speaker that caused some minor interference with the plastic housing and door panel.
wyomingtoy
Postby concealer404 » Wed Mar 18, 2009 7:16 pm
WarTowels wrote:http://www.lanzar.com/itempage.asp?MODEL=VX830
^These are interesting.
Specs:
SPECS
# Standard 8'' Size Fits OEM Locations
# Poly-Mica Coated Woofer Cone
# 1.5'' High Temperature Voice Coil
# Neodymium Dome Tweeter
# Film Cone Midrange
# Power Handling: 200 Watts RMS/400 Watts Max
# Impedance: 4 Ohms
# Frequency Response: 37-22kHz
# Rubber Boot Magnet Cover
# Mounting Depth: 3.35''
# Includes Grills, Wires and Installation Hardware
$28.00 + shipping at amazon.com
http://www.amazon.com/gp/product/B0007L ... -1&seller=
I don't know much about Lanzar, but these seem like they would been cool if powered by a small amp. I don't think it would be a great idea to power them through a deck since they have 200watt's rms.
I for one don't really want to put 8" subwoofers in my doors, I would prefer a real 8" mid bass driver or these, which are the 3 ways.
The only other "real" mid bass driver I can find for reasonable prices are from Pyle, but I don't know them either.
Thoughts anyone?
-Towels
A month and a half later... :P I'm going to ask why it wouldn't be a good idea to power these speakers through a deck?
Speakers don't "pull" power, if that's what you're getting at.
Cars and stuff.
concealer404
Postby wyomingtoy » Wed Mar 18, 2009 7:27 pm
Kicker SSMB 8's available thru Amazon.com at DiscountJungle for $127.
wyomingtoy
Postby RedCelicaTRD » Wed Mar 18, 2009 7:41 pm
concealer404 wrote:A month and a half later... :P I'm going to ask why it wouldn't be a good idea to power these speakers through a deck?
In order for a speak to sound its best it needs to have power. Those speakers have a fairly high RMS and I would assume the sensitivity is low, so if you where to power them off the deck it wont sound very good. The deck doesn't push enough power to make those sound good.
Postby concealer404 » Wed Mar 18, 2009 7:42 pm
The deck doesn't push enough power to make ANYTHING sound good....
I was just asking why he thought it wasn't a great idea. It's not going to hurt anything, is what i was trying to get at.
Cars and stuff.
concealer404
Postby WarTowels » Wed Mar 18, 2009 9:23 pm
I don't think it's not a great idea, because it isn't a great idea.
A) As Wayne stated, it will sound far less that optimum.
B) If you overpower an amp in an attempt to provide more power, it can damage the speakers.
So... not really sure what your getting at.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby concealer404 » Thu Mar 19, 2009 11:22 am
-Towels
All i was getting at was making sure that the common misconception that speakers "pull" power wasn't present. It's been prevalent across all the boards that i frequent lately.
But yes, i agree with both points, but neither are the end of the world if you exercise some common sense and caution and don't constantly play your music at levels that produce distortion.
As alluded to, nothing sounds good just running off a deck. :P
Cars and stuff.
concealer404
Postby WarTowels » Thu Mar 19, 2009 6:40 pm
Get good thing no one mentioned anything, anywhere, about pulling. :D
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby athousandleaves » Tue Apr 14, 2009 4:45 pm
Just tried to mount a set of kickers in my friends trac yesterday...
TOTAL HEADACHE! :doh:
were going to have to grind the doors down to make room for the speakers even after cutting the plastic up and resoldering the connectors to longer wires.
I can post some pictures if anyone is interested...
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby GT4RC » Tue Apr 14, 2009 9:24 pm
They don't pull power, but they do have a power rating. if you put speakers that are higher rated than the amp, and then crank up the gains to try and make em loud, not only can you blow the amp, but the distortion from the gains being cranked up will make them sound like shit.
spend $50 and get a used basic 4 channel speaker amp.
GT4RC
Postby YerRandO » Wed Apr 15, 2009 2:57 am
athousandleaves wrote:I can post some pictures if anyone is interested...
Definatly
-James
YerRandO
Postby turbo4wd » Wed Apr 15, 2009 4:24 am
Definatly
Also post up which model Kickers they are so we have a reference.
Dan
Undercover Moderator
turbo4wd
Postby athousandleaves » Wed Apr 15, 2009 5:16 pm
Kicker SSMB8's
I'll post pictures later tonight from home.
Has anyone else had to grind the door down to fit these in? Or am I installing them all wrong? :shrug:
1992 White turbo4WD
athousandleaves
