How many of you...
How many of you...
Postby Flying Bajan » Fri Apr 04, 2008 2:57 pm
Have a tachometer issue with your cars ? Is this as common as I've been led to beleive ? What causes them to stop working ? If I install a new tach, how long should it last before acting up again ?
Flying Bajan
Postby Gary » Fri Apr 04, 2008 4:02 pm
I have owned three 5th gen Celicas and never had any problem with tachometer.
93 ST185
Gary
Postby Tazka » Fri Apr 04, 2008 4:38 pm
I haven't had any problems with my tachometer.
What's wrong with yours?
Tazka
Postby etantshi » Sat Apr 05, 2008 4:13 am
No problems with the tach, the speedometer on the other hand......... :roll:
André B.
1991 ST185 (down but not out)
1990 ST185 (lost, but not forgotten)
1996 RZN140 (the daily)
2004 Yamaha R6 (needs a battery)
etantshi
Postby WarTowels » Sat Apr 05, 2008 4:34 am
Both of my tachs are fine also.
Both my speedo's occasionally make a buzzing noise, mostly when it's very cold.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby bloodMoney » Sat Apr 05, 2008 5:13 am
Mine works great most of the time. There are occasions though, where the tach will be dead for about 5~10 minutes of driving, then it'll suddenly wake up and work fine the rest of the drive... I really doesn't bother me much. I think its because I've only driven the car for about a month since having bought her 2 years ago...
~bloodMoney
88 ST165 'Patty'
90 ST185 'Ellie'
'96 GT "Abby" ~ RIP 11/17/2013
'96 GT 'vert "Lily" ~ RIP 08/22/2015
'04 LS430 "Alice"
'98 GS400
bloodMoney
Postby Flying Bajan » Mon Apr 07, 2008 4:33 pm
This car has had a problem with the tach for a long time now - even before I bought it. It simply refuses to work. Dennis Heath (past owner) has changed out the tach for another (used) one and it'll work for a while and then stop again he says.
I want my tach to work !!! It is extremely frustrating to not be able to find the source of this problem.
Flying Bajan
Postby Gary » Tue Apr 08, 2008 5:56 am
If Dennis can't fix this, I don't know who can. :doh:
Have you check the continuity of the tac signal wire.
It is the black one from igniter to the combination meter.
93 ST185
Gary
Postby Hotrodhendrix » Fri Apr 11, 2008 7:00 pm
Have you checked for issues on circuits?
http://alltrac.net/phpBB2/viewtopic.php?t=26888
Re: How many of you...
Postby monkninja » Wed Feb 16, 2011 5:17 pm
my tach doesn't move at all anymore, it was acting crazy for a couple weeks then dropped dead and hasn't moved since... thanks for the links for troubleshooting!
Kyle
1990 AllTrac
1999 Kawasaki ZX9R (Usual daily driver)
2003 Matrix Xrs (Wife's car)
monkninja
Postby aus jd 2703 » Thu Feb 17, 2011 1:50 am
Is it just me or is the stock speedo slow to react?
aus jd 2703
Postby tubasteve » Mon May 16, 2011 3:47 am
as far as the speedo i have found on both my cars the cable going to the trans it brakes at the end...crusie is the cheap one, $12.xx is what i just paid 2 months ago. also my shaft inside the houseing going to the trans, both jobs are easy just dont do it with the car hot ;)
feb. 1990 alltrac red one: fun machine http://tinyurl.com/Tubasteve
5x114 conversion: http://tinyurl.com/nu3qnez
tubasteve
