Toyota RC/Momo steering wheel on All-Trac?
Postby 2of81 » Sat Feb 26, 2011 8:56 pm
Taken from Etantshi's pic on the gallery section.
I was wondering what is needed to install this wheel onto my '93 US market column? What do I get rid of, if anything and do I need a momo adapter. All my wheel came with is a rubber boot to go between the wheel and column, when mocking it up on my white 93 something didn't seem so right. I would really want to install this on my red car and would want to do it right.
Justin
1972 Corolla TE27
2of81
Re: Toyota RC/Momo steering wheel on All-Trac?
Postby jonnyboygt4 » Sat Feb 26, 2011 9:08 pm
when i installed my aftermarket wheel with a 6 bolt pattern i used NRG's hub w/ quick release listed for an alltrac/gt-four with a momo, sparco bolt pattern...install went really easy and was a quality product....and my signal lights are still functional.....id recommend their stuff.....
91 JDM ST185
"just a little 4-banger"
jonnyboygt4
Postby 2of81 » Sat Feb 26, 2011 9:58 pm
Yea, this is made for an OEM Toyota and didn't know if I was missing something. It appears different than the normal 6 screw steering wheels.
Justin
1972 Corolla TE27
2of81
Postby jonnyboygt4 » Sat Feb 26, 2011 10:49 pm
pictures of the back side of that wheel would be nice.....
91 JDM ST185
jonnyboygt4
Postby Gary ST165 » Sun Feb 27, 2011 2:26 pm
2of81 wrote: It appears different than the normal 6 screw steering wheels.
in what way is it different?
i always thought my RC Momo wheel had the generic 6 screw Momo fitment... same as my other Momo wheel, and uses a genuine Momo boss.
ST165 turbo 4WD
Gary ST165
Postby Toyota_Todd » Mon Feb 28, 2011 11:51 pm
The pad that goes in the center of the steering wheel is removable. Once you remove it will see the 6 screws that mount the steering wheel to the hub adapter. Some guys like to use the MOMO steering wheel without the pad, just different taste.
Todd Longenbaugh aka Toyota_Todd
1992 Celica All-Trac Turbo "Seeing Red"
1992 Celica GT-Four RC Conv. "Fatal Alltraction"
2001 Avalon XLS "the wifes family truckster"
1971 Pontiac Ventura II "The token domentic"
Toyota_Todd
Postby underscore » Mon Apr 18, 2011 3:26 am
did you just get the boot, or is there a mount under the boot? If you remove the USDM steering wheel ( a few screws and one big bolt) then the Momo whel will go right on, provided you indeed have the adapter.
