Audio System Help!
Audio System Help!
Postby GingerGT-S » Sat Apr 23, 2011 11:13 pm
Okay, so I'm sure these topics have been made before and i have been searching through them to no end and i need an exact answer.
in my 90 GT-S i had the system 10 stock radio,speakers etc . But my radio signal was crappy the speakers were coming through a bit fuzzy and static like because of the old head unit. So as a commuter everyday i like the radio, i decided to get a new head unit. I figure i buy one and all the speakers will work.
well i changed the head unit and the dash and rear speakers work and sound great, but my door subs do not work. Mind you i have the factory amp installed. I purchased new speakers and put them into the door but nothing worked.
the solutions I'm seeing are to "bypass" the factory amp, manually wire the speakers to existing wiring that's in the new head unit, but what does this entail. Also, if i put a new amp in how does this get to the actual head unit. i have a clarion CZ100 and it has a built in amplifier which powers the 4 speakers already, but how will the 2 speakers be powered and connected to the head unit, in which the head unit already has an amplifier?
summary : i have an aftermarket head unit that powers my 2 rear and 2 dash speakers and i bought new speakers for the door woofers. how can i get them to work without doing too much work?
thank you very much for your help, my grandfather and i are trying to find a way to do this that won't be super elaborate.
GingerGT-S
Re: Audio System Help!
Postby Boo_Guy » Sat Apr 23, 2011 11:30 pm
You need a Toyota / Lexus integration harness, and your stereo will need two sets of RCA outs.
Check the link for info;
viewtopic.php?f=22&t=7679&start=30
Boo_Guy
Postby GingerGT-S » Sat Apr 23, 2011 11:39 pm
i have a 1990 GT-S though w/ the system 10 system, so from what i have read that harness won't work?
GingerGT-S
Postby BoostedBlueToyotas » Sat Apr 23, 2011 11:55 pm
What you really need is a Autoleads PC9-406. I bought mine off a english ebay site. Works perfectly on the 2 piece 90 systems (verified).
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby GingerGT-S » Sun Apr 24, 2011 12:02 am
so by purchasing this harness, it plugs into my aftermarket HU and into the factory amp connector that was connected to the original factory HU, which will then lead power into the woofer speakers?
a how to would be SUPER helpful if anyone can give me one, electric is really confusing.
GingerGT-S
Postby GingerGT-S » Sun Apr 24, 2011 12:24 am
also if it helps, i ordered my radio from crutchfield and it came with installation instructions as to harnesses and what wires to clamp.
i'm just looking to get the door woofers working, the new speakers i got have built in tweeters, so the door ones closest to the mirror aren't a necessity.
thanks to anyone who can help me :(
GingerGT-S
Postby BoostedBlueToyotas » Sun Apr 24, 2011 9:35 am
Do a search on it. It has the RCA leads built it and yes it allows you to use the factory amp and wiring harness and the door speakers work :)
http://cgi.ebay.com/PC9-406-Autoleads-T ... 43a164bf63
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby GingerGT-S » Sun Apr 24, 2011 10:30 pm
hm yes, i just had an epiphany and realize that my radio had inputs in the back, rather wires coming out, so I'm assuming these are the wires this harness will connect into.
However, i need to find out which place the adapter plugs into for the factory amplifier.
does anyone know where the above harness connects into?
GingerGT-S
Postby GingerGT-S » Sun Apr 24, 2011 11:32 pm
correct me if I'm wrong but here is what I'm getting from other posts
-the wires that i connected to my aftermarket head-unit with the included harness play my 2 sets of speakers (2 dash and 2 rear) but it also sounds like the wires that are connected to the door subs are in there, but when i put the new radio in, i lost power to the amplifier.
-the amplifier only has use to power the door subs
so if i purchase a new amplifier, my door subs will work, without any necessary re-wiring?
unless my previous post method is correct?
a visual walkthrough from anyone who has done this would be SO great, this is becoming a headache :doh:
GingerGT-S
Postby Boo_Guy » Sun Apr 24, 2011 11:43 pm
GingerGT-S wrote:i have a 1990 GT-S though w/ the system 10 system, so from what i have read that harness won't work?
The harness I mentioned as well as the autoleads one runs the subs in the doors with the rca connections. Its just not listed as a part for our cars, well the metra one isnt, but it works.
GingerGT-S wrote:so by purchasing this harness, it plugs into my aftermarket HU and into the factory amp connector that was connected to the original factory HU, which will then lead power into the woofer speakers?
Yes, the two sets of rca outs will use the stock wiring ans amp to run the subs in the doors.
Right behind the radio, using the original toyota stereo plug, if you havent cut it away that is.
Boo_Guy
Postby Boo_Guy » Sun Apr 24, 2011 11:48 pm
Buying a new aftermarket amp would be more hassle, not less. You would have to run your own wiring to the amp and subs, the power and rca's. Instead you plug in the harness that would use the stock amp and wires.
Boo_Guy
Postby GingerGT-S » Sun Apr 24, 2011 11:57 pm
okay so the plugs from the Autoleads harness (the RCA ones will go into the rca plug-ins located on the back of my radio here
http://www.gotbump.com/files/3656354/up ... 0_back.jpg
then, i take what is plugged into the back of my radio and plug it into the white connector, and plug the black connector into the other connector?
(sorry if its vague)
and my woofers, dash and rear will all work??
thank you so much for the help !!!!
GingerGT-S
Postby Boo_Guy » Mon Apr 25, 2011 12:39 am
The one that I bought doesnt have that black connector on it;
http://cgi.ebay.com/ebaymotors/Metra-70 ... ioQ5fVideo
To be honest I havent installed these parts yet myself, Ive got the harness and a dvd stereo waiting for me to install.
I know the rca's will send sound to the subs in the doors, there is probably a wire to signal the amp to turn on, and I dont know what the others are for yet. So I dont know what else will or wont work, but some lexuses (lexusi?) have the same sort of system.
You should read the other stereo thread and the original on celica tech, for some with the GTS this harness didnt work, seems to depend on the year and / or the type of factory stereo that the car came with.
http://www.celicatech.com/trance4c/The% ... mation.htm
This is probably confusing as shit, Im sorry, I just dont want you to waste your money
Boo_Guy
Postby GingerGT-S » Mon Apr 25, 2011 3:01 am
http://i.seimg.net/images/33665/main/met-701761.jpg
this is the harness that came with my aftermarket head-unit
my grandfather and i cut and crimped the wires according to the color and got the dash and rear speakers to work.
i don't mind putting money into getting the harness, i just would like to know where it connects.
i am going to take apart the radio and i figure go from there.
i wish i could get this done by a pro, but they would charge an arm and a leg.
thanks so much for your help, if you know anymore, feel free to elaborate.
GingerGT-S
Postby BoostedBlueToyotas » Mon Apr 25, 2011 7:43 pm
One end of the autoleads harness connects into the factory harness that would have plugged into the back of the system 10 unit. The other end has RCA jacks that will plug into the out (RCA) of your aftermarket head unit. 2 locals have used this and it was PLUG and PLAY :) In my 14 yrs of owning alltracs this is the ONLY harness I have seen that is plug and play on a 1990 - 91 celica 2 piece system 10 setup !!!
Tim Plessing
Columbia, MD
BoostedBlueToyotas
