Climate control leds
Postby woot woot » Thu Apr 28, 2011 6:13 am
Hey all i wanted to change the bulbs in my climate control unit to white ones in my JDM ST185.
I have changed them over and can get them to light up individually when touched with multi metre but when plugged into car have the leds will not light up, and have no idea whats wrong.
Any tips??????????
woot woot
Re: Climate control leds
Postby phattyduck » Thu Apr 28, 2011 4:45 pm
Are they in there the right direction? LEDs only work in one orientation.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby toayoztan » Thu Apr 28, 2011 5:37 pm
Yeah, the LEDs have polarity.
What kind of LEDs did you get though?? A naked/raw LED works off about 3 volts. Hooking up directly to the car of a 12v source will destroy them. You need to put in a resistor.
A lot of "automotive" LEDs are sold that already have built in/soldered resistors to use in cars, as well as some being able to allow the LEDs to dim.
www.superbrightleds.com is where I went to grab all of mine.
Did you read the big thread about changing over the climate control bulbs to LEDs too?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby aus jd 2703 » Thu Apr 28, 2011 8:43 pm
Be aware I swapped mine tO super bright blue LEDs and now at night the blind me. I'm yet to find a fix :(
aus jd 2703
Postby woot woot » Sat Apr 30, 2011 3:00 am
I put them in the right way with the polarity cause i left one in and tested it then put the new ones in. I did not read the led install guide though. I saw the Vader Gt4 with them (Looked really really good) and wanted to match the white leds i put in my dash cluster and thought i knew what i was doing.......lol. Worst of all i dont think i changed anything besides the leds and now cant get them to work.
Yeh i did not want to blind myself so went for in the middle brightness LEDs ( have done the same thing in the past lol).
Can u send me a ink for the led guide? I tried to look for it but found some other ones
woot woot
Postby woot woot » Sun May 22, 2011 7:02 am
Figured out the problem, i did not turn the key enough in the ignition.......... IDIOT...... lol
woot woot
