Interior dimmer switch
Postby woot woot » Sat Jun 25, 2011 11:58 pm
Hey guys have not been able to find much info on this,
My JDM GT4 did not come with a dimmer switch for the interior and so my dash and climate control lights are very dim. (Hence why the dimmer) I found a large square female connector with four flat inserts under the dash and wondered in anyone knows what this is. I already took a dimmer from a AUS St184 but has a three male pins.
Does anyone know if there is a different dimmer for JDM GT4 or if the female plug can be spliced into the normal ST184 plug. Again not sure what that plug under the dash is for. Hoped it was for the dimmer switch.
Thanks for the help
woot woot
