ECU!!!!!
ECU!!!!!
Postby zgookgumby » Wed Aug 24, 2011 3:33 am
Ok. I open up my ecu and noticed that one of the fuse is burnt. Is there a way to repair it or just buy a new one?
zgookgumby
Re: ECU!!!!!
Postby Boo_Guy » Wed Aug 24, 2011 12:34 pm
I had eprom installed into an ECU once by a TV / Electronics repair shop, maybe you could take
the ecu into them and get an idea of the cost to fix it?
If that was too much id start surfing ebay for a new one.
Boo_Guy
Re: ECU!!!!!
Postby klue » Wed Aug 24, 2011 11:32 pm
Was there a problem with it that caused you to open in?
Re: ECU!!!!!
Postby bridge47 » Thu Sep 01, 2011 7:18 pm
To be more specific. Yes, you have a problem that cannot be fixed by just replacing fuse.
Fuses blow because:
1) Some lame ass previous owner fogot to connect all grounds to factory connections. See also anyone else who failed to document disassembly steps and does not work on vehicles 24/7.
2) Do not feel bad if this is you; we have all been there at some point. Consider it a paid lesson in automotive education. It is how you move on that counts.
3) Become thoroughly famaliar with the use of a muti-meter. This is the last thing most techs learn. Learn it now and reap the benefits.
Facts are stubborn things.
bridge47
Re: ECU!!!!!
Postby cmonteiro1 » Fri Sep 02, 2011 11:30 pm
Not sure what alltrac you're driving, but I went AEM so I'm pretty sure I've got an old ECU from my 91 alltrac that I could shoot your way cheap
1991 ST185
Mods:
Aussie DP, 3in Exhaust, Wideband A/F, BayArea FMIC, HKS SSQ Blow Off Valve, Forge Waste Gate Actuator, AEM ECU, SARD 800 , Walbro Pump, ATS Fuel Rail Mod, ATS Fuel Pres. Reg. Mod., 60 trim upgraded ct26.
cmonteiro1
