Antenna swap
Antenna swap
Postby bluetrac1209 » Wed Nov 09, 2011 2:59 pm
My power antenna on my st165 is broken and stuck completely out. I want to get a non-power one that is shorter. Anyone done this and have any suggestions on an antenna that will work?
bluetrac1209
Re: Antenna swap
Postby CMS-GT4 » Wed Nov 09, 2011 4:02 pm
You need a base for a screw type antena. I know a lot of the 5th gen guys buy the y2k celica base from the dealer and then a s200 antenna. I found that base 5th gens had a screw base, so I picked one up at a junk yard then I got a stubby antenna for a celica and it was done in a few minutes.
Here is the final outcome. I imagine 4th gen chassis is going to work in a similar fashion.
Re: Antenna swap
Postby Meurz » Wed Nov 09, 2011 9:11 pm
Josh, rub some silicone spray on the side of your tank cover :wink:
Turbocelica.nl
Meurz
Re: Antenna swap
Postby CMS-GT4 » Wed Nov 09, 2011 9:25 pm
Yeah that one side of the tank cover needs to be painted. That will be a spring project.
Re: Antenna swap
Postby toayoztan » Wed Nov 09, 2011 11:05 pm
Antenna looking good with that modification.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Re: Antenna swap
Postby OutToWinPAHC » Mon Dec 03, 2012 9:42 pm
My car head no radio when I got it, so when I put on in i found out the antenna was bad when the motor shot it out and kept going. Not knowing if it was the antenna assy or the amp relay I rather not spend money on used parts to ruin them. So I am looking to do this too, but can you tell me if you had to run the antenna wire to the head unit, or did it simply unplug from the power unit and plug into the new celica manual base?
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC
Re: Antenna swap
Postby aus jd 2703 » Mon Dec 03, 2012 10:36 pm
CMS-GT4 wrote:You need a base for a screw type antena. I know a lot of the 5th gen guys buy the y2k celica base from the dealer and then a s200 antenna. I found that base 5th gens had a screw base, so I picked one up at a junk yard then I got a stubby antenna for a celica and it was done in a few minutes.
got part numbers? so keen to do this!
aus jd 2703
Re: Antenna swap
Postby CMS-GT4 » Tue Dec 04, 2012 12:25 am
No part numbers. I grabbed one off a fwd narrow body celica in a junkyard. I hear you can use the parts from a y2k celica as well.
Re: Antenna swap
Postby 93cc » Tue Dec 04, 2012 11:48 pm
mine was stuck about 2/3's up and wouldnt go up or down either... I removed the guts of the antenna and pushed the antenna all the way down and disconnect the power and then connect the antenna cable that goes to the rear window to the head unit. You will need an Antenna adapter but thats it.
93 Black AllTrac
13 Scion FRS - Current Daily Driver
81 Black/Blue Celica - Sold
2007 Silver Tacoma Sport
93cc
