BraveUlysses":224qx4zc said:
Turbo timer I assume?
Pull off the trim underneath the steering wheel. It should be held on with about 7 or 8 screws. Remove the metal brace underneath that, and you will find the ecu harness--plug your harness into it and find a spot to mount your turbo timer. Put it all back together
Kris, you sure you mean the ecu harness?
That's on the other side, on the firewall/floor....
*Unless you mean the other wires that go from the ecu. It's not really the ecu harness. :shrug: More of a dash harness[it runs all over the dash]*
Chris, that's so no-one can steal the car. If you set the ebrake, with the timer on, and you release the lever w-out a key in the ignition, it will kill the engine.
