dashboard warped, how to remove?
Postby uncivilised » Thu Dec 01, 2011 8:46 pm
So recently I purchased a gt4, interior is in very average condition. The dashboard (mainly the part above the steering wheel and before the windscreen) has been warped by exposure to sun and has holes etc (basically looks really bad). I have found a spare dashboard from a st183 ready to scrap however how would I go about removing the dashboard? Does anyone have good instructions or pictures on how to do this? Thnx guys, any input is very much appreciated.
Toyota Celica GT-Four 1990 - Main car
New Zealand
uncivilised
Re: dashboard warped, how to remove?
Postby Corey » Thu Dec 01, 2011 11:30 pm
I just did this job a few months ago. It's time consuming, but straight forward enough. When I get home I'll dig up the instructions for dash removal I have.
Otherwise, you should be able to find them on celicatech in a write up about System 10/interior.
What I would recommend doing before you install the new dash is to apply a layer of glue (I used JB weld) around all the edges that tend to warp. It's my hope that the glue will help prevent the dash from warping in the future.
Basically, you start by removing the seats, the door sill covers, the shift boot and center console. Then work your way up from there: the stereo, glove box etc.
Cheers
Corey
Corey
Images: 50
Postby uncivilised » Fri Dec 02, 2011 3:55 am
Corey Darling wrote:I just did this job a few months ago. It's time consuming, but straight forward enough. When I get home I'll dig up the instructions for dash removal I have.
Cheers
Corey
Thnx Cory, will be awaiting those instructions :)
New Zealand
uncivilised
Postby toayoztan » Fri Dec 02, 2011 5:01 am
I've forgotten how to remove it too (been a while, year ago), but I THINK it involves removing or getting around the blower unit under the glove compartment, but not completey sure on that. Also, will have to remove the instrument cluster, the clock, etc.
Like he said though, it's a pretty straightforward task, just look around for the bolts. However, don't forgot there may be bolts behind the vents (remove the vent lever knob, then the vent should just pull out with a good tug).
Just take your time, got slow, and don't start pulling on the dash hard.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby Corey » Sat Dec 03, 2011 4:44 am
Cheers
Corey
Images: 50
Postby BNZ » Sat Dec 03, 2011 8:53 am
Does anyone has the exact same "how-to" steps for the ST165 ? Thanks
Street ST185
Rally ST165
HillClimb Renault 5 GTE
BNZ
Images: 31
Postby uncivilised » Thu Dec 08, 2011 5:19 am
thank you so much corey!
New Zealand
uncivilised
Postby monkninja » Fri Apr 27, 2012 1:50 am
Thanks Corey! I am using this right now as I attempt to install a viper alarm system, I can't find this in my BGB....
Kyle
1990 AllTrac
1999 Kawasaki ZX9R (Usual daily driver)
2003 Matrix Xrs (Wife's car)
monkninja
Postby Ghost1 » Thu Jun 14, 2012 11:59 am
This should be a sticky.
Ghost1
Postby 4rsnduction » Thu Jun 14, 2012 12:30 pm
Ghost1 wrote:This should be a sticky.
+1 to that
Almost every old celica suffers from the dash warping
4rsnduction
Postby 819_ay » Sun Jun 17, 2012 7:55 pm
i agree !!
819_ay
Postby zero06 » Tue Oct 09, 2012 9:14 pm
is there anymore info on the hardware and quantities? I have everything apart and lost the box i put all the hardware in :bangshead:
zero06
Postby toayoztan » Wed Oct 10, 2012 3:36 pm
zero06 wrote:is there anymore info on the hardware and quantities? I have everything apart and lost the box i put all the hardware in :bangshead:
I have my dash out and the bolts in a ziplock bag. I can find it and take a pic of what I have.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby Locker » Thu Dec 12, 2013 12:36 am
Thank you Sir! this was very helpful.
90 ST185
Locker
Postby underscore » Thu Dec 12, 2013 12:52 am
This is very good info, it doesn't look nearly as bad as I had thought.
