For those that "upgraded," ideas on stock boost gauge?
Postby toayoztan » Mon Dec 05, 2011 6:47 am
So, going MAP with the AEM EMS-4, the stock boost gauge will be "dead" and not doing a thing.
What did you guys do about this...leave it? Rig it up to read pressure vs vac? Replace your whole cluster with GTS?
Just curious.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Re: For those that "upgraded," ideas on stock boost gauge?
Postby celicat93 » Mon Dec 05, 2011 2:24 pm
I was thinking I would mount an aftermarket one over it. I don't know that it would function any better than it did for boost. :shrug:
celicat93
Postby klue » Mon Dec 05, 2011 2:28 pm
I just blanked mine off, it sucks anyway :P
You can fit some smaller gauges in there with some modifications, or if your using AEM ems, you can use the serial gauges to read outputs off the EMS directly
So cool :P
Postby underscore » Tue Dec 06, 2011 1:24 am
my plan is to get a slim gauge, and mount it in front of the stock boost gauge. same deal with water temp.
Postby RedCelicaTRD » Sat Dec 17, 2011 1:24 am
Stock gauge still works with an AEM installed. Still as slow and still as inaccurate.
Postby celigts » Sat Dec 17, 2011 2:50 am
Is it possible to like cut out the out boost gauge and place a pod there?
3SGTE project motor very slow
celigts
Postby Caconman424 » Sat Dec 17, 2011 5:22 am
Ive seen some people replace it with the same section out of a gts. Looks clean and stock
91 Red AllTrac, Minneapolis, MN
Caconman424
Postby underscore » Sat Dec 17, 2011 6:13 pm
my GT-S just has a huge water temp gauge in that spot? what's the benefit of that?
Postby celigts » Sat Dec 17, 2011 6:46 pm
Is it even possible to cut out the old boost gauge? Seen someone change it on the forum somewhere??
celigts
Postby rio_cyber » Sat Dec 17, 2011 7:03 pm
afaik mr2 guys put omori boost gauge in there clusters , so that should fit ...
http://forums.bcmr2.com/viewtopic.php?f=12&t=11324
<-----My avatar represents the state of my ST165 :(
rio_cyber
Postby celigts » Sat Dec 17, 2011 7:38 pm
That looks really nice!
celigts
Postby underscore » Sat Dec 17, 2011 8:45 pm
I really like that idea, more info on the gauge?
Postby lumbercis » Sat Dec 17, 2011 10:39 pm
what makes the stocker so slow and innacurate? If it's just the sensor, why not get an improved sensor and rig it up to the stock gauge indicator? I think that would be pretty cool for BPU type setups..
Caldina powered...
lumbercis
Postby celigts » Sat Dec 17, 2011 10:51 pm
Cuz aftermarket can look sexy if slim fitted. ;) and why keep it stock. Mods are sick in any way. I think lol
celigts
Postby sMARTINside » Sun Dec 18, 2011 12:37 pm
Because it is an electronic gauge, it must have a fast response compared to mechanical one. Good idea!
sMARTINside
