For those that "upgraded," ideas on stock boost gauge?
Re: For those that "upgraded," ideas on stock boost gauge?
Postby soarer.jzz30 » Wed Mar 19, 2014 4:46 pm
Do you realize that the gts gauges are the same on that dial, and in fact identical except for the volt meter being in place of the boost gauge. I will go take a picture later today. Blow your mind
soarer.jzz30
Postby soarer.jzz30 » Wed Mar 19, 2014 4:48 pm
On another note why did you post a picture of rhd trac gauges
soarer.jzz30
Postby warracer » Wed Mar 19, 2014 5:37 pm
soarer.jzz30 wrote:On another note why did you post a picture of rhd trac gauges
Because I own a rhd gtfour?
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby soarer.jzz30 » Wed Mar 19, 2014 5:41 pm
Then use a rhd gts cluster piece..
soarer.jzz30
Postby underscore » Wed Mar 19, 2014 6:28 pm
soarer.jzz30 wrote:Do you realize that the gts gauges are the same on that dial, and in fact identical except for the volt meter being in place of the boost gauge. I will go take a picture later today. Blow your mind
Which year/market GTS? My 92 USDM doesn't.
Postby soarer.jzz30 » Wed Mar 19, 2014 6:35 pm
I used a 93 gts on my 90 trac both usdm. It's only a couple of screws that hold it in place what seems to be the issue.
soarer.jzz30
Postby soarer.jzz30 » Wed Mar 19, 2014 7:41 pm
[attachment=-1]uploadfromtaptalk1395261545332.jpg[/attachment]
Plus the aluminum bezel, but if you notice it's all in place. If I remember correctly now, I think I used the gts cluster and put the all-trac tach and speedo in it, I also used the flat wiring from the gts as well. Everything is wired from factory to function
soarer.jzz30
Postby CSAlltrac » Wed Mar 19, 2014 9:46 pm
Two roads for ya Bryan
Racepak Display
Stack Display. :D
Postby ALLensTRAC » Thu Mar 20, 2014 12:10 am
CSAlltrac wrote:Two roads for ya Bryan
Racepak Display
Stack Display. :D
+1 for Stack!!
Allen
ALLensTRAC
Postby warracer » Thu Mar 20, 2014 1:29 am
soarer.jzz30 wrote:Then use a rhd gts cluster piece..
rhd gts cluster are almost impossible get. And pricier than doing the mods im doing right now.
But thanks for the diligently proposed advice
____________
ST185H A-Spec:
warracer
Postby soarer.jzz30 » Thu Mar 20, 2014 1:44 am
Too bad for you.
soarer.jzz30
