Indiglo install questions
Postby UtahSleeper » Mon Mar 19, 2012 6:11 pm
So, I have a st165 and one of the PO put indiglo faces on. I like them and want to use them, but I dont want to have the power switch and knob to go from green to blue. Has anyone installed these faces and did you install them in a more "stock" fashion?
I would prefer to have them power up when I turn on running/head lights. Just not sure what to do about making it only show blue.
UtahSleeper
Re: Indiglo install questions
Postby phattyduck » Mon Mar 19, 2012 10:31 pm
Just power them from the power for the interior bulbs (not the variable ground) and turn the knob to blue. Then you can just leave it under the dash instead of out exposed.
I'd tell you the wire color, but I only know the Camry one. :twisted: You can find it on the dash rheostat. There will be three wires - one ground (probably white with black stripe), one that is 12V with the parking lights on and one that is variable with the knob.
-Charlie
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby Redrkt01 » Tue Mar 20, 2012 7:53 pm
^ What he said. I have the indiglos too so speak up if you have any other questions.
1989 ST162
1988 ST165 Black
1988 ST165 Red Parts Car
Redrkt01
