New ST185 OEM key blanks
Postby AFCor » Mon Jul 09, 2012 7:24 pm
I found these at Twosrus.com ( http://twosrus.com/catalog/product_info ... cts_id=441 ) and picked up a couple. You could use the part # and get them through another parts retailer if you want. They're not too bad! I mean, it's what you'd expect a factory key to be. And it's one more thing that makes the car a little nicer especially if you have a hardware store key like mine was. It "feels" better, you know?
-Anthony
'90 All-trac - His
'98 Land Cruiser - Hers
'02 Jetta TDI - DD (50+MPG)
AFCor
Re: New ST185 OEM key blanks
Postby Autobot » Mon Jul 09, 2012 8:12 pm
Nice! I will have to pick these up. :)
Autobot
Postby phattyduck » Mon Jul 09, 2012 9:21 pm
Getting new keys was like the second thing I did when I got my Alltrac. Mostly so the old worn keys wouldn't fall out of the ignition anymore. :D
You can get the factory cut at the dealer with your VIN or key code for an exact fit.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby AFCor » Mon Jul 09, 2012 10:47 pm
phattyduck - I was wondering what to do about cutting the key. Mines worn down so much there are no more edges. Thanks for the tip!
-Anthony
'90 All-trac - His
AFCor
Postby underscore » Wed Jul 18, 2012 6:32 pm
How much does the dealer tend to charge for cutting them by VIN?
Postby 88gt4DE » Thu Jul 19, 2012 5:12 pm
I just got same thing for my 165 ... different style and looks kewl 8)
Postby celi_wabbit » Sat Jul 21, 2012 1:53 pm
Here is mine, cut and uncut.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
1991 Celica Alltrac - Sold
1994 Celica GT - Project
2010 Mercedes-Benz
celi_wabbit
Postby celigts » Sat Jul 21, 2012 2:26 pm
Celiwabbit those look sick
3SGTE project motor very slow
celigts
Postby Autobot » Mon Jul 23, 2012 2:08 am
Looks nice, but for some reason I prefer the OEM key.
Autobot
Postby celi_wabbit » Mon Jul 23, 2012 11:17 am
celigts wrote:Celiwabbit those look sick
Thanks!
Autobot wrote:Looks nice, but for some reason I prefer the OEM key.
No prob... everyone has different taste. Plus, OEM is safer route.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
2010 Mercedes-Benz
celi_wabbit
Postby sinerasis » Fri Nov 16, 2012 6:35 pm
Are 165 OE blanks available somewhere? I would really like to get a few.
Could the possibly be the same as the MK1 MR2 keys? (http://twosrus.com/catalog/product_info.php?products_id=440)
Jeff
1989 ST165 Black
sinerasis
Postby OutToWinPAHC » Fri Nov 16, 2012 7:04 pm
I actually got a few from them, perfect
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC
Postby 88gt4DE » Sat Nov 17, 2012 1:34 am
sinerasis wrote:Are 165 OE blanks available somewhere? I would really like to get a few.
You mean these ? were still avail a month ago at my work ... however yer screwed on making keys off key codes for 165 at dealer now unless you already have code. Not in system anymore. Locksmith may be able to cut them by code with an example lock ...
Postby sinerasis » Sat Nov 17, 2012 1:41 am
That's the correct part number? I shouldn't have much trouble having my existing key copied right? I don't NEED the code do I?
Jeff
1989 ST165 Black
sinerasis
Postby 88gt4DE » Sat Nov 17, 2012 2:36 am
Correct number sir. Just got mine a month ago or so. If yer existing key isnt too worn then you can copy them off of them. Yer call ... or take yer trunk cylinder out or any of the locks and a lock smith can get code and cut them off that. Only two ways I know since code wasnt available in toyota parts database anymore ...
