New ST185 OEM key blanks
Re: New ST185 OEM key blanks
Postby sinerasis » Sat Nov 17, 2012 2:52 am
Right on, thanks for the info!
Jeff
1989 ST165 Black
sinerasis
Postby 88gt4DE » Sat Nov 17, 2012 1:13 pm
No problem ... that why we are here :wink:
Postby Toyota_Todd » Fri Jan 11, 2013 2:35 am
A little known secret is to pull the passenger door lock cylinder. It has a code scribed into the body of the lock cylinder. With this code your dealer or lock smith should be able to cut keys for your Toyota.
In some rare cases you will have a metal tab that a previous owner may have given you with a key code stamped on it. Sometimes its on a spare set of keys and most people have no clue what it is. Rare, but it happens from time to time.
One other long shot is to look in the owners guide (not the owners manual) if your vehicle came with one. Believe it or not, back in the good ol days...salesmen actually wrote down the key code for the customer in the owners guide. I have found keys codes this way for a few Toyotas.
Good luck on your key code searches!
Todd Longenbaugh aka Toyota_Todd
1992 Celica All-Trac Turbo "Seeing Red"
1992 Celica GT-Four RC Conv. "Fatal Alltraction"
2001 Avalon XLS "the wifes family truckster"
1971 Pontiac Ventura II "The token domentic"
Toyota_Todd
Postby sinerasis » Fri Jan 11, 2013 3:41 am
Would the drivers lock cylinder have the code too?
I think it's possible my passenger door was replaced once upon a time, that or the lock is broken. I was thinking I could see if they match.
With that said, could I order a lock with a specific code from a dealer?
Jeff
1989 ST165 Black
sinerasis
Postby Toyota_Todd » Fri Jan 11, 2013 12:16 pm
Hey Jeff,
The lock cylinder code is only on the passenger door lock cylinder only. As for the new lock cylinder that you need... when the dealer orders it in, it will be a random code. You can than have a locksmith recode it to match your vehicle.
Do this first. Take the code off the passenger lock cylinder and get your local dealer to cut you a cheap key for checking it for fitting the rest of the car.
Another option is to find a member parting one out that has all of the locks together in a set and change them all out. When I parted out a couple cars, I sold 2 compete lock sets. I had the key codes written out for them too.
Toyota_Todd
Postby sinerasis » Fri Jan 11, 2013 4:10 pm
Kinda lame they wouldn't just label all the locks.
I have a key, which works in the drivers door and the ignition. I think it works in the back too, but I'm not 100%. Just the passenger door doesn't work I think. So either the door/handle/lock was replaced or the lock is damaged somehow.
Jeff
1989 ST165 Black
sinerasis
