Radio removal on an ST165
Postby Killtodie » Fri Aug 17, 2012 4:55 pm
I didnt spend too much time looking, but I could not find any bolts or pry points to get the radio out. I will also need to remove the center console, is there a DIY somewhere? I keep finding 185s not 165
Thanks!
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Re: Radio removal on an ST165
Postby UtahSleeper » Fri Aug 17, 2012 5:27 pm
You will need to remove the console around the radio to remove the radio. The center console and radio console are help in by screw around the outside.
UtahSleeper
Postby underscore » Fri Aug 17, 2012 5:40 pm
I remember from my 162 that the 4g is a massive pain compared to the 5g. I know you have to remove the glovebox for starters.
Postby Jason88AllTrac » Fri Aug 17, 2012 7:54 pm
Glove box, center console, and lower dash panel all need to come out, then you will be able to remove the bezel and the screws holding the radio in.
White 88' ST165 :: Blue 88' ST165
Jason88AllTrac
Postby 88gt4DE » Fri Aug 17, 2012 9:12 pm
Yup ^ Correct ... Pita ....
Postby Killtodie » Mon Aug 27, 2012 7:50 am
Thanks, I got the panels out. Not hard at all, taking this opportunity to remove everything else and clean. Air ducts are very dirty and so is everything else.
Killtodie
Postby Rick89GTS » Wed Aug 29, 2012 12:57 am
Yep, a PITA but I've done it so many times now I can get in and out in 20 mins
Rick89GTS
