Radio removal on an ST165
Killtodie
I didnt spend too much time looking, but I could not find any bolts or pry points to get the radio out. I will also need to remove the center console, is there a DIY somewhere? I keep finding 185s not 165
Thanks!
UtahSleeper
You will need to remove the console around the radio to remove the radio. The center console and radio console are help in by screw around the outside.
I remember from my 162 that the 4g is a massive pain compared to the 5g. I know you have to remove the glovebox for starters.
Jason88AllTrac
Glove box, center console, and lower dash panel all need to come out, then you will be able to remove the bezel and the screws holding the radio in.
Killtodie
Thanks, I got the panels out. Not hard at all, taking this opportunity to remove everything else and clean. Air ducts are very dirty and so is everything else.
