Door Speakers Not Working
Postby nextmod93 » Fri Aug 31, 2012 4:48 pm
Hi i wired a soundstream amp to my door speakers and they wont work. the amp turns on but no sound comes out of the speakers, i took a battery to the speaker wires and both sides did make sound. i have a kenwood excelon x794 deck if that helps with info... what can be the problem?
nextmod93
Re: Door Speakers Not Working
Postby fussellbug » Fri Aug 31, 2012 5:21 pm
Assuming your amplifier is connected to the subwoofer RCA outputs of your head unit you should check the following settings based on your head unit user's manual:
http://manual.kenwood.com/files/4c3ba7dce1f5d.pdf, page 38 shows audio settings where the subwoofer output has to be turned on, and page 42 shows subwoofer size setting where you should select something other than "none".
fussellbug
Images: 36
Postby nextmod93 » Fri Aug 31, 2012 7:58 pm
fussellbug wrote:Assuming your amplifier is connected to the subwoofer RCA outputs of your head unit you should check the following settings based on your head unit user's manual:
so i just need to tune my deck and the door speakers should work? and do the RCA in the deck need to be put in "front" or "subwoofer"? i thought front because the speakers are in the front and im not running subs..
nextmod93
