165 no working interior electrical
Postby Hash » Sun Sep 09, 2012 10:08 am
So I bought this 165, horrible decision. I have one working dash backlight. I'm thinking it was a transplant motor and was wondering where to start. My alternator has a wire that won't stay in the plug, so let's just say is pure battery power untill iget a new plug in. any ideas though? Not sure where to start..
88 gt4 #7262 - barely running salvaged title, 185k kilometers (Canadian car?)
88 Camry 5spd 300k+ new timing belt, head gasket, etc
70 F250 2wd 429scj
Hash
1988 Toyota Camry
Re: 165 no working interior electrical
Postby quieter » Sun Sep 09, 2012 12:36 pm
go get a new clip (plug) from any electronic store (the ones that carry IC's, boards, etc...) and solder both ends and put shrink wrap . you should be good. respect the wires thickness (AWG) if you dont want to start a fire. match it or go bigger. take your whole dash appart and change the lights. you an always go to the dealer and ask them for the lights or go to the scrapyard. good luck with your new acquirement!
2011 BMW 535xi M pack (daily)
-Simon
quieter
Postby Hash » Mon Sep 10, 2012 7:01 am
It's not just the lights, i'm just lost as where to start. I have no gauges windows a/c ..
70 F250 2wd 429scj
Hash
1988 Toyota Camry
Postby 88gt4DE » Mon Sep 10, 2012 11:47 am
Check all the fuses to start with ... " gauge " fuse will knock alot of stuff out ...
Postby Hash » Mon Sep 10, 2012 9:13 pm
And the fuses are good. I'm guessing that the wiring harness is screwed
70 F250 2wd 429scj
Hash
1988 Toyota Camry
Postby Awesome-Trac » Mon Sep 10, 2012 9:28 pm
Get a multimeter and check each fuse to see if your circuit is open or closed when energize it by turning the system on. Another thing you can try to do is hitting the circuit breaker on either driver or pass side near the kick panel, see if anything turns on
•Daniel
Awesome-Trac
Postby Hash » Mon Sep 10, 2012 9:31 pm
Thanks, I'll try that when I get my battery back, my buddy is charging it.
70 F250 2wd 429scj
Hash
1988 Toyota Camry
Postby underscore » Mon Sep 10, 2012 9:35 pm
Replace some of the fuses anyways, sometimes a fuse that looks good can still be bad.
Postby Hash » Mon Sep 10, 2012 9:36 pm
True, but shouldn't I check for continuity first?
70 F250 2wd 429scj
Hash
1988 Toyota Camry
Postby underscore » Mon Sep 10, 2012 10:09 pm
If you have the tools/knowledge to do so, yes. I just know that wiring is like black magic to a lot of people so I tend to assume they won't know how/what to use to do that (sorry!)
Postby Hash » Mon Sep 10, 2012 10:21 pm
I'm no electrical genius but I do have a$500 fluke so I should be able to do just about anything, however there is stuff I need to do before I start and i'm very limited on funds ATM. :/
70 F250 2wd 429scj
Hash
1988 Toyota Camry
Postby quieter » Mon Sep 10, 2012 10:25 pm
do a continuity test on the fuses too even if you eyed them, might of cut off because of a falsy grommet or bad connection in the pins. but for real your problem sounds like a fuse. happens alot when you switch the radio and connect a 12v wire to a ground or touching a metal part like the brackets or the radio case
-Simon
quieter
Postby underscore » Mon Sep 10, 2012 10:30 pm
Oh and at risk of sounding silly (but to cover all bases) I'm assuming you've checked all the fuse boxes & relays?
Postby Hash » Mon Sep 10, 2012 10:37 pm
I've been told that relays very rarely go out, so I haven't. A fuse/relay box hangs loosely under the hood, as part of the battery holder has been cut to make way for the front mount ic i'm guessing, so i'm trying to figure out how to mount that...
70 F250 2wd 429scj
Hash
1988 Toyota Camry
Postby 88gt4DE » Mon Sep 10, 2012 11:19 pm
Stock it was mounted on side on battery tray but alot of people axe that when they do A straight intake setup ... there are a few things in the underhood fuse block that will control things in the car. when you get yer battery back start with voltage tests across the fuses. You have that fluke meter so set it to DC volts and ground the black. Use the red to look for voltage at the fuses , some will be at all times and others with the key on ... start with just that and see what ya find ... :smokes:
