My engine bay fuse box (2x) relocate
Postby Spectra1 » Thu Dec 20, 2012 4:33 pm
Im in the process of splitting the engine harness so that only engine related components are on the harness that is attached to the engine. While I was at it I decided to relocate both of my engine bay fuse boxes to help clean up the engine bay. I also tucked the body harness so that it only runs in the fenders. Im not fully done with this yet but here is what it looks like so far.
Hole cut in drivers side fender
Hole as viewed with drivers side fender removed
Fiberglassed insert to hold and position both fuse boxes. Custom molded.
Fuse boxes installed into access hole with fiberglass insert. Im not done with the wiring yet so it looks a little messy.
Finished look from inside of engine bay
I will be fabing up a cover for the rear of the fuse blocks to protect them as well as a cover for the engine bay side. In the close up finished pics you can see that there is no longer a body harness visible within the engine bay. It has been moved to the inside of the fenders. Ill post up more pics when it is finished.
93 St185 DD
90 ST185 - Project
Spectra1
Re: My engine bay fuse box (2x) relocate
Postby underscore » Thu Dec 20, 2012 5:02 pm
I never have and never will understand the point of tucking the harness and making everything harder to fix, that said you've done a nice job of hiding the fuse box while still making it accessible.
Postby Spectra1 » Thu Dec 20, 2012 5:08 pm
In 20+ years the wire harness has never had to be "fixed" so why would I care if it was in the engine bay? If something ever needed work all I would have to do it remove the fender which takes a total of 10 min. On the other hand the engine bay will now look 100X better so to me it makes complete sense. As for the fuse boxes I figured I would need access to the often hence why I did what I did instead of simply hiding them in the fenders.
93 St185 DD
90 ST185 - Project
Spectra1
Postby toayoztan » Mon Dec 24, 2012 7:40 pm
Because I got rid of my AC along with "its" fuse box, I only have the FP Relay and Horn relay from it, and then of course the big fuse box.
I am thinking about tucking, but making it accessible possibly from the cabin. Not sure what I plan to do yet. I will probably split my engine harness so nothing runs under the radiator. Therefore, the Passenger headlight, headlight motor, corner light, and turn signal will have to transfer to come out of the passenger side. I plan to upgrade and relocate my horn.
Great job with what you've done there! I was considering a similar set up, but I like to leave that area for drawing in fresh air for the intake.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby soarer.jzz30 » Wed Mar 19, 2014 7:27 am
This is beautiful! Great work
soarer.jzz30
Postby Spectra1 » Wed Mar 19, 2014 3:30 pm
Thanks. I was in the process of really cleaning the whole harness up, eliminating a ton of wires (I have an autronic standalone), and hiding/tucking what I could. I wish I could post up a updated pic but the car is 2000 miles away while im in school. Maybe some day it will be finished :( .
93 St185 DD
90 ST185 - Project
Spectra1
