Small dash problem
Small dash problem
Postby warracer » Tue Jun 04, 2013 7:54 pm
Alright so recently Ive noticed my dash started to ''Un-glue''? itself next to the vent. When im driving I can't notice it but outside of the car its pretty noticable, Ive been wondering if any of you guy encountered this issue, and if so how did you fixed it? I thought about re gluing it but Im not sure on which adhesive I should use, technique etc.
Here's a picture of the problem :
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Re: Small dash problem
Postby underscore » Tue Jun 04, 2013 9:06 pm
my RC is like that, if you find anything out please post it up.
Postby aus jd 2703 » Tue Jun 04, 2013 9:39 pm
very common with st18X celica's, you can try gluing it down but realistically you should have the dash re-skinned by an upholsterer. i was quoted $500 to install new padding and vinyl, it would be as it left the factory. this is in Australia.
aus jd 2703
Postby warracer » Tue Jun 04, 2013 10:30 pm
Ouch :doh:
Ill try something myself next weekend then :)
____________
ST185H A-Spec:
warracer
Postby Corey » Wed Jun 05, 2013 1:57 am
You can reglue it.
Mine had the same issue. To fix it I ordered another RHD dash that was in far better shape. When it arrived I found it had started to separate a tiny bit as well.
So to fix it and make sure it wouldn't get worse - I used JB weld epoxy to glue that grey foam pad back down onto the black plastic under lay. I used lots of text books and free weights to pin it down in place while it cured.
Then I swapped the dash out.
There is no way you'll be able to glue that back in place while its in the car. It will need a lot of weight if it was as warped and stiff as my old dash was.
Corey
Images: 50
Postby warracer » Wed Jun 05, 2013 2:40 am
Corey Darling wrote:You can reglue it.
Thing is my dash is warped, yes. But it is still super tender, I can still bend it in place easily, ill try something next Saturday, should be interesting, and if it doesn't work, Ill just have to order an other dash, by the way where did you order your's?
____________
ST185H A-Spec:
warracer
Postby Corey » Wed Jun 05, 2013 2:56 am
I ordered mine from a member on the gt4oc who was parting out his RC.
Good luck
Corey
Images: 50
Postby warracer » Thu Jun 06, 2013 6:43 pm
Corey Darling wrote:I ordered mine from a member on the gt4oc who was parting out his RC.
Good luck
Ill need it thanks ! :)
____________
ST185H A-Spec:
warracer
