Power stays on after key removal in '91 longer than '90
Postby ascribe » Fri Sep 06, 2013 3:43 am
Ok so here's the deal. Just after you turn the '90 off and remove the key, you can work the windows and moonroof and such until you open then door. However, in my '91, you can still work the electronics for some time even after the doors have been opened. Does anyone know what the actual physical difference is between the two years that allows this? My old '93 gt was the same way.
I would really like to replicate how the '91 acts for use in the '90.
Thoughts?
ascribe
Re: Power stays on after key removal in '91 longer than '90
Postby underscore » Fri Sep 06, 2013 4:14 am
Do the door switches work in the 91? Ie do the door lights come on when you open it?
Postby ascribe » Fri Sep 06, 2013 4:36 am
Most of the time. I can see if it has any effect though.
ascribe
Postby ascribe » Fri Sep 06, 2013 1:34 pm
Yep looks like that was it...guess the door switches in my 93 didn't work either. Aaaand now I feel like an idiot. lol
ascribe
Postby Corey » Fri Sep 06, 2013 3:49 pm
Mine is backwards.
Once I remove the key there is no power, but when I open the driver's door, power returns so I can close the windows and sunroof. It then shuts off once the door is closed.
Mine was built in Sept 89
Corey
Images: 50
Postby ascribe » Sun Sep 29, 2013 8:26 pm
Wow really? That's sure strange.
ascribe
