wire harness swap??
wire harness swap??
Postby mongo » Fri Mar 14, 2014 10:34 pm
hey my brother and i bough an engine, and it's from japan so the wires tend to go or come out from the other side and the ecu is to far for it, is there a way to wire swap it? or by any chance is there a better way to connect the wiring harness to the ecu????
1990 white all-trac
Images: 12
Re: wire harness swap??
Postby celicast184 » Sat Mar 15, 2014 1:54 am
what i did with my gts swap is i cut a hole into the firewall right behind the engine. the hole was probably about 4-5 inches above the steering rack. this way, the wire feeds right into the cabin where the ecu is at.
I <3 MY ST214
Postby soarer.jzz30 » Wed Mar 19, 2014 7:20 am
Open it, cut it, extend it. Seal it back up
