Fuse block relocation thread (ideas and suggestions)
Postby soarer.jzz30 » Wed Mar 19, 2014 7:44 am
Well I have the harness out again and I have the battery relocated. I would like some options for relocation the harness, I am either thinking I'll put it in the hatch where the jack used to be, or possibly in the drivers fender. I have a custom made cols air box that has some extra space, but I would really like to eliminate it from under the hood because the wiring is ridiculous and it's crowded enough with the gen3 swap and all the wta gear. From what I've heard I would have to run completely new wires from point to point because of possible voltage variations that are caused by having to much resistance due to increased length.
soarer.jzz30
Re: Fuse block relocation thread (ideas and suggestions)
Postby celicast184 » Wed Mar 19, 2014 8:43 am
i relocated mine in front of the car. i bolted it right under the grill support bracket that holds the faux carbon grill.
I <3 MY ST214
celicast184
Postby soarer.jzz30 » Wed Mar 19, 2014 8:46 am
Interesting idea.
soarer.jzz30
Postby MWP » Mon Mar 24, 2014 9:34 am
This is what ive done :twisted:
I now have only 4 relays in the engine bay (head lights, rad fan, horn), and no fuses.
Everything else has been moved behind the passenger seat.
Postby soarer.jzz30 » Mon Mar 24, 2014 10:00 am
Wow. That's beautiful, I'm going to assume that's all new hardware on everything.
soarer.jzz30
Postby MWP » Mon Mar 24, 2014 12:05 pm
Ive re-used all the original wiring where i can.
The relays/fuses are obviously all new.
Ive had to go through every single wire in the car, work out what its for, why, and if it was still needed, then reroute it or remove it.
How power is routed around the car has all changed, so for future reference ive drawn up new wiring diagrams for it all too :)
Its been a massive job.
You can see where ive mounted the MegaSquirt3 ECU in the second photo.
The blue frame will have aluminium sheet fitted and then carpeted.
So ill have one big flat floor right to the back of the car.
Postby 819_ay » Fri Apr 25, 2014 12:03 am
soarer.jzz30 wrote:Wow. That's beautiful, I'm going to assume that's all new hardware on everything.
i am going to have to agree , that is pretty!!
819_ay
