Intercooler level sensor wires are where?
Postby Gordon12 » Thu Apr 10, 2014 6:08 pm
Hi guys, been looking but can't find much. My car never had the water intercooler when I got it. Working on clearing code 54. But code 23, where is this connector at that I need to bridge? Can I do it at the ecu? If so which pins? Thanks much.
Gordon12
Re: Intercooler level sensor wires are where?
Postby Gordon12 » Fri Apr 11, 2014 4:28 am
Some one?
Gordon12
Postby soarer.jzz30 » Fri Apr 11, 2014 9:22 am
Take the grey/red wire on pin 15 of the 22 pin (c) and ground it. That should fix it i would use an intake ground but it doesnt matter really. Or if you find the two pin connector under the hood making a bridge pin or even splicing them together works to.
soarer.jzz30
Postby Gordon12 » Fri Apr 11, 2014 1:06 pm
Awesome thank you. Yeah I have no clue where that connector would be.
Gordon12
Postby underscore » Fri Apr 11, 2014 2:45 pm
The connector should be near the tranny end of the valve cover.
Postby Gordon12 » Fri Apr 11, 2014 2:58 pm
Hmm, alright I'll look, thank you. I'll probably take a pic and post just to confirm it's the right one, if found.
Gordon12
Postby Gordon12 » Mon Apr 14, 2014 7:50 pm
Gordon12
Postby Gordon12 » Mon Apr 14, 2014 7:51 pm
Gordon12
