Arduino Clock replacement; Altimeter,Temp,Clock w/date
Postby bajallama » Tue Sep 30, 2014 1:11 pm
I've been working on a clock replacement for my 165 for a while. I wanted to integrate a boost gauge into the clock but then decided not to because the clock is kind of a distance away and not really easy to see while driving. I had made this boost gauge already though:
http://www.projectz61.com/design/arduino-boost-gauge/
Here is a thread over at MR2OC I started which had input that sparked my interest in a more complicated gauge:
http://www.mr2oc.com/showthread.php?t=474962
Basically the complication was that without another pressure sensor to reference, if you ascended, the value read by the electronic boost gauge would be off as you climbed in elevation (Since atmospheric pressure drops). This goes for most MAP based fuel injection systems also. If you are confused, take a read here:
http://www.fastfieros.com/tech/map_sensors_and_how_they_work.htm
Does this mean an analog gauge sucks? No, it's just not accurate. I wanted to make a boost controller/gauge using a barometric sensor to properly regulate "Real" boost, to avoid blowing my engine while I climbed steep hills. I live at around 800ft but I drive to my cabin every other weekend which is above 6000ft.
So I made the altimeter that will eventually output a signal to another Arduino boost gauge. I am working out the final wiring diagram so if you guys ever want to make one yourself, you can. The buttons are replaced with a single aluminum bar that acts as a capacitive sensor. so it's touch sensitive to switch between the screens. I might sell a kit with everything you need including all the 3D printed parts to hold the screen and sensors, you would just have to do the soldering and wiring. If you're good at programming you can change the fonts. The splash screen is also very easy to make, I whipped this one up in MS Paint in about 20 minutes. Here are some quick shots:
ProjectZ61.com
bajallama
Re: Arduino Clock replacement; Altimeter,Temp,Clock w/date
Postby underscore » Tue Sep 30, 2014 1:15 pm
That looks awesome!
Postby GT4_DRED » Tue Sep 30, 2014 3:19 pm
underscore wrote:That looks awesome!
X2..
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby Awesome-Trac » Tue Sep 30, 2014 5:36 pm
That's pretty badass
•Daniel
Awesome-Trac
Postby FC Zach » Wed Oct 01, 2014 5:02 am
I would love one of these for the st185.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby monkey8oi » Thu Oct 02, 2014 9:05 pm
I'm sold..
monkey8oi
Postby 93cc » Thu Oct 09, 2014 10:24 pm
Very cool
93 Black AllTrac
13 Scion FRS - Current Daily Driver
81 Black/Blue Celica - Sold
2007 Silver Tacoma Sport
93cc
Postby Anoo21 » Fri Oct 10, 2014 12:19 pm
I'mall for this Iif you can get the kit going. sweet Job man
Anoo21
